Question about Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier
Kenwood amp i recently bought 2 kenwood kac-x1r's and have no idea where the settings should be for opt performance for my subs, i need to know soon as possible.
  • limpit8 Feb 18, 2008
    x series alpine 12"
  • Fred Corral May 11, 2010
    what subs are you trying to push with these amps?
    Problem Solver:
  • 4 Answers
Should've asked more.. LOL.
Depends on a couple things.. I'll try to guide you as much as possible and if you have any question just let me know.
If you are running these subs on a ported enclosure or band pass, do you know the tuning frequency of the box? If it is sealed, I would assume it is 35 Hz + -5.
Also, can you select the frequency for the subs from the Head unit? If so, bring your HU's xover at 50-6- Hz. On the amp itself, turn the gain at 3/4 and you could either get the amp's xover at 50hz or below (that'll depend on your taste). the wiring of the woofer should be in parallel so that you can drop the impedance to 2 Ohms.
The band reject filter is for letting through "other" frequencies than the ones you have specified... which I see it as a good idea so leave it to off,
The band reject frequency, leave it at 40 Hz
Your woofer does great at low frequencies, so the bass boost frequency set it for 60-70 Hz.
Also, since you'll be using this for subs, make sure you have yout dial to LP (Low Pass/Through/Hi Pass)
The high pass dials you don't have to mess with as they aren't used on Low pass.
Something to note. If your stereo has Low Pass frequency adjustment, the amp will already be receiving only low frequencies, so, if you want to leave it in Through (or full) it will not matter, thus I had to admit that this Amp gives you room for seting the audio exactly as you want.
This will be the setting I would use according to my experience and my ear... but, it will depend on your taste as you'll be the one riding it.
if you have any question please let me know.
by the way, hopefully this was useful to you
Posted on Feb 19, 2008
My kenwood kac 9103d just crapped out on me and i am looking to buy a new amp but when i bought my sub the guy specifically wanted to know what type of amp i had to match it to the sub. so now do i have to...
More specifically, the amp must support the resistance of the sub, or subs. If your amp is 2-ohm stable, it can run a sub, or subs wired for a 2-ohm load. Also, whatever the recommended maximum wattage is for the subwoofer, try not to exceed this much, if at all, with the amplifiers wattage.
Jan 18, 2011 | Kenwood KAC-9103D Car Audio Amplifier
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
May 12, 2010 | Kenwood KAC-X1R Car Audio Amplifier
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI KENWOOD KAC X1R??
Es un monoblock amplifier, esto significa que el amplificador es de un solo canal, y este tipo de amplificador no se puede conectar en bridge.
Aug 11, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Jun 11, 2009 | Kenwood KAC-719 Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier Logo
63 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
