Question about Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier
Lanzar viberant 5.0 farad cap
I have 2 + and 2- on my cap what is the other set for? i thought maby its for the power going in and power going out. first time hooking one up.
    Sergeant:
  • 300 Answers
Both "+" connections on the cap are tied together within the cap, as are both "-" connections. Lanzar provides two sets to allow the cap to be more easily shared between the power/ground lines of two amplifiers. If you have only one amp, connecting to one or both of the +/- sets should not matter (although connecting to both +/- sets might reduce the resistance between the cap and the power wiring of your amp).
Posted on Mar 05, 2008
Telecharge viber
What is the problem you faces with this amp? Provide more details; please. http://electronicshelponline.blogspot.com/
Dec 08, 2014 | Lanzar VIBE426 Viberant 4 Channel 1600...
Does not shut off
with the car running the cap should be on. there is an adjuster near the terminals. be ready to adjust. run the car for a minute and then sut it off and adjust it so just turns off within a minute of sutting the car off. it may take a couple tries to fine-tune it. it now, should automatically switch on and off as the voltage changes between running, and resting.
Jun 21, 2012 | Lanzar Opticap 50 5 Farad 24v Oval...
Need to know correct replacement part for dual capacitor
You can use a universal dual capacitor it doesnt have to look the same just match the numbers it will probably say 30uf/5uf or what ever the number is. If this help please rate me and do a testimonial
Jun 15, 2011 | Heating & Cooling
How to charge the lanzar 1.6 capacitor
typically you can charge or discharge large capacitors using a resistor. Not just any resistor will do. You will need one with high-enough resistance and wattage ratings or you'll burn up the resistor. I would use a 1/2W, 4.7kohm or a 1W, 1kohm. These are minimum values and you can use a slightly higher resistance but it will take longer to charge/discharge.
To charge, connect the positive terminal, then hold the resistor between the ground wire and the ground terminal for 30-60 seconds. Then connect the ground terminal. To discharge, disconnect both terminals, then hold the resistor across the terminals (do not reconnect terminals without charging). In either case, you can use your fingers to hold the resistor as DC will not shock you, but if the resistor gets hot it will burn you. I use needle-nose pliers to hold the resistor (just in case). Just be careful not to short the resistor leads or terminals with the pliers.
Explanation: For a standard cap 1 - 2 farads, the discharge voltage is up to 20V so we'll figure off of that. I would use at least a 1/2 watt resistor, a 1 watt could be safer, depending on the value. For a 1 watt, the current can be no more than .05A at 20V. For a 1/2 watt, only .025A. Let's say .04A and .02A, respectively. Ohms = Volts / Amps, so 20V / .04A gives us 500ohms. Double that to be safe (avoid overheating) and it's 1kohm. Same process for the 1/2W version will be 2kohm, but it's not as hefty, so I would recommend 4.7kohm.
Jun 29, 2010 | Lanzar 16 Farad Power Capacitor LQ16CAP
Looking for a service manual for a Lanzar Viberant 1200W Amp
www.lanzar.com/manuals/VIBE226-236-246-256-266-276-286-416-426-436.pdf
Mar 03, 2010 | Lanzar - Viberant: 2 Channel 1200W...
25 farad cap slowly losing its charg if the car sits for to long
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Dec 24, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Amp turns off for a bit and back on when it hits hard
You do not have enough power coming from our car battery, your alt. may be going out. Look into a 5 farad power cap to store more power...
Apr 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
My amps keep turning off
that is possible,but you might need to run an another battery so they can get the suffenent power and you will need a bigger alternater
Mar 08, 2009 | Alpine MRV-1507 Car Audio Amplifier
Cant figure out how to wire a power acoustik 5 farad power cap.
Use to independent grounds always better that way. Better full field for power and less distortion. I like to use 4 guage or lower like 0 guage for high powered systems. Good luck, thanks for using FIX YA
Jan 09, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Power Cap or Deep Cycle Battery?
your amplifier has the following specs:
Output Power at 12V:
1 x 200W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 400W @ 2 ohms (0.5% THD, 1kHz)
Output Power at 14.4V:
1 x 300W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 600W @ 2 ohms (0.5% THD, 1kHz)
a .5 farad cap should work fine for 12v applications, a .75 will work fine for 14.4v applications. If you plan on upgrading the stereo system in the future, you should probably just pick up a 1 farad now and save trouble later.
when mounting the cap, mount it as close to the sub as possible. i recommended a deep cycle battery in an earlier solution due to the power handling requirements for the amp and speaker combo, any time you are working on a competition or semi-competition setup, you will want to isolate your audio system as much as possible from your vehicle's main electronics. i normally use a deep cycle battery if it's going to be a comp/street combo as you can sit at the lake and jam all night without killing your main battery. for comp only use, i stick to optima batteries, they seem to work well and can dump loads of amperage pretty quick.
if you go the dual battery route, you will want to buy a battery isolator to make sure the two batteries are independent of each other.
hope this helps,
trin
Nov 19, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier Logo
97 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
