Question about GE JEM31 Microwave Oven
Will not pop popcorn without burning it
No matter what I do this microwave always burns popcorn. I have tryed the popcorn setting first and also just time and waiting for the pops to almost stop and it still burnt it. I switched to mini bags of popcorn thinking it would work but it still burnt it. Does this need repair because maybe the heat is not correct. The only thing I really use a microwave for is popcorn and reheating and I have never had this problems with other microwaves.
This is still under warrenty. I bought all new GE products when we remodeled are kitchen less than a year ago and have never gotten the microwave to work with popcorn.
  1. Model JEM31SF01 Serial Number AM900703B
Sue Guess
1715 W. French Ave.
Orange City, FL 32763
email- dflawless@embarqmail.com
    President:
  • 1,314 Answers
Use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Posted on Feb 16, 2008
Microwave popcorn
Could be your KitchenAid microwave only works with bagged popcorn.
Jan 22, 2014 | KitchenAid Microwave Ovens
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
Burn popcorn???
I have never found a microwave oven that worked perfectly for popcorn. If you are using the "popcorn" button it can only guess at what your popcorn needs. This is my soultion at work as well as at home or a fiends place. I watch the process and listen to the pooping. When it get down to two seconds between pops I shut it off. Each type of popcorn will act differently but if you keep using it and keep using the same microwave, eventually through a process of testing you can come to a time that will work with your process. One other thing the popcorn has to be on a rotating table and has to be put in with the correct side up. You will never get it perfect but you want to cut it off before it begins to burn.
Sep 20, 2010 | LG LRM1260SW Microwave Oven
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
GE JEM31 Microwave Oven Logo
919 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
