Question about GE WSXH208A Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
My ge front load won't spin clothes out leaves them soaking, takes forever and now it's pausing unlocking and locking door without finishing a wash
  • lorijar Feb 18, 2008
    Same problem here. The clothes are soaked when the cycle is done - that is, if it actually completes the full cycle. It just keeps pausing and unlocking the door. I've RECLEANED the filter (tip I learned on this site previously) but there was nothing in the filter this time so now I'm hoping for another miracle solution from you FixYa techs! Come on - don't let me down!!! :-) Lori
  • davew111 Mar 05, 2008
    Exactly the same problem.....any suggestions?
    Sergeant:
  • 236 Answers
Sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Posted on Feb 16, 2008
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 11, 2008 | GE Washing Machines
The washer will not spin and the load of clothes is still wet it clicks on and off within 1 minute and the door is not staying locked
i would consult the technical papers within the lower unit, but i believe if the door latch is not locking, or otherwise broken it will not enter the spin cycle therefore leaving the clothes very damp indeed.
best of luck,
ttfn
Oct 22, 2009 | GE WSXH208A Front Load Washer
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Oct 01, 2009 | GE WSXH208A Front Load Washer
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
MY DUET SPORTS DOES NOT DRAIN.
your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door won't unlock
remove bottom panel reach up to lock area pull down on small tab to release door if tub has water in it remove pump filter aacess by turning counterclockwise (have towels handy dip out as much water as possible first)
Sep 09, 2008 | Kenmore 46462 Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
613 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
