Question about LaCie BRICK (301063U) 300 GB Hard Drive
I dropped it on a floor. Now it gives an alarm sound.
Hi
I dropped my lacie 300GB hard drive from my couch while it is still connected to my laptop.
Immediately it did not respond and now every I put the power on, it gives an alarm sound and does not seem to work.
Please give me an Idea as I have got all my wedding album and videos in this without any backup.
Kindly advice.
regards,
Ashok.
    Genius:
  • 3,587 Answers
Wow..you'll need to get a data recovery expert to 'snapshot' your drive to attempt to recover your data. I'd suggest that the 'drop' did a major mechanical deal, like a head impact crash. Not good. A local tech store/computer shop MIGHT have the tools to extract the data. Last time I checked, it runs from 100 to 300 bucks, depending on what kind of files are retrieved.
Posted on Feb 16, 2008
I want to change hard drive in my lacie brick 300gb, but i dont know which hard drive comes in ATA or SATA drive
You'll need to open the case
ATA will have pins on the drive that the cable attaches to
SATA will have 2 cables side by side that plug into edge connectors on the drive
May 16, 2011 | LaCie BRICK (301063U) 300 GB Hard Drive
It fall on the floor then i connected it to my pc
Sorry, the hard disk was damaged and this is unfixable, junk it. Try to open the case and extract it, maybe if you connect it directly it will work long enough to recover some of the data you stored on it.
Jun 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie won't register that it's empty
Click Start
Right-mouse click My Computer
Click Manage
Double-click Storage
Double-click Disk Management (Local)
Right-mouse click on the 60GB partition
Choose Delete Partition
Click on the 300GB of "unallocated" space.
Create a partition that "spans" the 300 GB.
Format the new partition.
Jan 16, 2010 | Computers & Internet
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear in...
The drive letter and USB port are not inherently tied together. you can give it a drive letter as long as nothing else is going to use that letter inherently, and be fine. Did giving it "F" work?
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
''No files found'' Lacie Silverscreen 500gb
You'll need data recovery to fix this problem. If the hard drive makes broken sounds there is a hardware problem. You can try to do data recovery yourself, there is some good content on youtube. If you want somebody else to do it for you there is Data Recovery NYC. Also there is good informaation on logic board repairs on hddguru.com.
Nov 14, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Lacie 120GB dropped
If you open it up you will see that the drive is a regular computer drive. You should be able to plug it into a computer as a secondary drive and try to get the data off. But if it's clicking and making noises there may be no hope. Sorry!
Jan 23, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
File transfer size limitation for LACIE HD
hi
can i suggest that you use winrar to divide the file size of your file that you want to transfer to your lacie. this might work.
download winrar @ majorgeeks.com
but if you LACIE still says that it does not have any disk space left...i would suggest that you reformat the HD instead. but make that a last resort...
hope this helps
Jan 21, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie BRICK (301063U) 300 GB Hard Drive Logo
194 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
