Question about Kirby Ultimate G Bagged Upright Vacuum
On/Off Switch won't depress
The On/Off Switch on my Ultimate G Kirby presses down and then sticks so that it won't power off... I finally pulled the plug, and now I plug it in and the vacuum won't come back on... the button won't go in or out when pressed. What could be the problem and do you have any suggestions?? PLEASE?! Is this something covered by the Warranty?
    President:
  • 1,673 Answers
Sounds like the switch finally went out completely. But there could be something with the linage to the switch, just will have to be opened up and check to see what the problem is. As far as warranty, if you still have warranty on this, then it would be covered. Your owner manual should tell you how long your warranty is from the date of purchase.
Posted on Feb 16, 2008
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
Jul 07, 2017 | Kirby Vacuums
How do I convert a kirby ultimate G from 110V to 220V
You can't. The Kirby draws too many amps for a step down transformer.
Ask Kirby direct if they can convert your head to 220V. click Support - Contact
Kirby Ultimate Vacuum Kirby Models
Nov 10, 2016 | Kirby Vacuums
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Intemitant power
DO NOT TURN ON THE KIRBY ANYMORE UNTIL YOU GET THIS FIXED!!! (not even to show someone what it sounds like)
Your carbon brushes are worn out and will cause damage to the armature if you run the machine before they are replaced..
You can use my guide for replacing the power switch to break the Kirby down and allow you to get to the carbon brushes to replace them.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Jun 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you change the off swith in the Kirby ultimate G
First Thing to check is, Is it the pedal or the actuall switch.. the main switch is on the motor up under the cover and on the side
it is a pain to get to and even worse to change out.
most of the time it is the pedal that is broken and it is attached the switch by a rod
check that first
WP Vac
wpvac@centurytel.net
Feb 09, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g handle staying upright
Please see my online guide for replacing the power switch. It will get you into the case. Just use this link....
Hope this helps...
Marci
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
