Question about ASUS A7V8X Motherboard
Replacing Motherboard with combo
I have the HP a635w Pavilion and the screen just turns blue. Tested hard drive ....checked ok....What combo do you recommend for this particular brand of computer?
  • HotOlds May 11, 2010
    I too have an HP Pavilion a635w. i think i did something to ther mother board. i pulled the ram and installed more, when i turned on the pc it just beeps. i turned it off pulled out the new ram & put back the old. Same thing. I pulled all the ram and turned it on, same thing. so i am thinking that i damaged the motherboard. can you tell me what motherboard to purchase so i can get this puppy up and running. i think i found it for like $50, if so then i am happy. here is the link..... http://www.amazon.com/dp/B0013DO2PC?smid...
    President:
  • 2,351 Answers
You can just replace your video card. If your using the Hp A635w with the intergrated video it may have just died. You sill have a free AGP slot on the board. Buy a AGP card with DDR2 or DDR3, change the bios setting to boot to the AGP card first & Bingo! Your up & running. The HP A635w is a Micro-ATX form factor: 9.6 inches x 9.6 inches. Thats the board size & that is what you'll need to fit that HP case. Micro-ATX's limit you CPU type & speed. Like dual core's.
I've listed one board combo doing a quick search & this board will take your current memory & fit the HP case.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3594506&body=MAIN#detailspecs
As I mentioned you can go for the AGP card listed in this link. Six pages of AGP's.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
It's up too you pick your flavor. Enjoy!
please vote...
Posted on Feb 16, 2008
When power is turned on, one long beep and two short ones. No screen dispaly but lights are on. I am told the motherboard is gone.
the beeping sound is the post system searching for your hard drive and other connected devices make sure the RAM has a secure seating also
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
At boot up I get the XP loading then stops. I get the blue screen of dealth. I placed the hard drive in another HP Pavilion dv 9000 and it works find. So, can I fix it or get a new motherboard
1. Try to clear all the dust by using blower and not sucking section. If possible use soft brush to clear any hard dust.
2. Try removing memory and replacing it after cleaning the slots.
3. Remove the processor and replace it in position, at the time of replacing even clean the heat sink compound and apply new heat sink compound.
After 1 and 2nd step try turning it on. It it does not help then only try the third step
Sep 05, 2010 | HP Pavilion dv9000 Motherboard
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
I need a motherboard for a HP a310N pavilion
Hi friend,
You need to check *********** board RAM. I think your RAM not connected by motherboard. second thing you need change your RAM Then....
Dec 19, 2009 | HP Pavilion a310n PC Desktop
"No IDE device" in BIOS drive selftest in HP Pavilion zd8000
any moisture on the motherboard
will destroy components if plugged in
even if yoru laptop is cold in your car , is ok
but when you bring it inside and plug in fast
condensation can burn out the tiny components, motherboard is bad
Jul 18, 2009 | HP PAVILION ZD8000 SEREIS 100GB (4200...
Blue screen
If it were me, a blue screen sometimes means something really serious could have happend. I would let a computer specialist check it out.
Nov 07, 2008 | HP Pavilion ze2000 Notebook
Motherboard problem for a 754 socket
I found this replacement motherboard with a simple google search:
http://www.google.com/products?hl=en&safe=off&q=HP+Pavilion+a635w+motherboard&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Jun 25, 2008 | ASUS A7V8X Motherboard
Pavilion a635w motherboard problem
Hi HotOlds, you did not hurt the motherboard. You did not install the memory correctly. Take the old memory & look at the contacts on the DIMM. There is a notch there & a notch in the memory slot. These two notches must be matched up when inserted. Each memory slot has a locking tab at each end of the slot. When you insert the memory correctly the locking tabs snap closed ensuring the memory will not come out. The beeps you are hearing are telling you the memory is not seated correctly. Same for the memory you bought. However, the memory you did buy must match the memory for the Pavilion A635W. This link will show memory you can use for the Pavilion A635W motherboard.
http://www.google.com/products?hl=en&q=HP+Pavilion+A635W+memory&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
(Buying a new board).
The link you have posted for the ECS Gf6100-M754 MB. Will not take the memory you currently have. You will have to buy DDR3 memory but that is not the main issue. If you intend to put this motherboard into the Pavilion case it may not fit. Measure the board in the HP & check the dimensions of the ECS board you want to buy. You will have to buy a new CPU as well. The HP uses an AMD CPU & the ECS uses an Intel CPU. Basically you will be buying a whole new system including the CPU & memory, which may not fit in the HP case. You will also need a higher power supply to run the ECS board. HP's power supplies are much smaller.
Good Luck!
I will not be online here at fixya for the next week or so.
Mike
Video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
Nov 27, 2007 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
ASUS A7V8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
