Asrock AM2NF6G-VSTA Motherboard Logo
Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On boot i get 3 short beeps twice but the pc then starts ok
Neciforo Llanto
Level 2:
President:
  • Expert 942 Answers
  • Posted on Jan 27, 2010
Neciforo Llanto
Expert
Level 2:
President:
Answers
942
Questions
0
Helped
315969
Points
109
When you here a 3 short beeps during turn on that is a RAM problem. So you need to check the RAM remove it first and clean the dust. Use also the other memory slot,
Anonymous
Level 2:
New Friend:
  • Expert 96 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
17657
Points
267
Please pull out the memory and clean the silver coating pins with a rubber eraser to clean dust and stains that causes disconnection.
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
1helpful
6answers
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
1helpful
No signal on monitor, vga tested and ok
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
2helpful
2answers
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
IBM Workstation giving 3 short beeps in 3 sets- not booting
hi im josh in cebu phils. may i help you? the problem of your IBM pc is ROM errors that gives 3 beeps in series of 3 sets 9beeps in all.
You need to replace you cmos battery on the mother board.12voltd batt. it maybe empty thats why it beeps or go to setup bios.then restore all the defaults in your pc. and the last one no choice reflash or reformat your pc there maybe files that are missing.
Start up boot
Two short beeps = "Parity circuit failure"
This code usually means a problem with either the system memory or the motherboard.
Solution: change the memory if still beeps then motherboard is defect.
I have an Asus p4s533-mx motherboard which boots and runs fine (sometimes). But when I perform a warm boot, it often won't pass POST. The beep code is one long and two short. If I power it down and let it...
The response from ASUS tech support - It's a standard Award BIOS, so they're the standard beep codes.
So I wrote the following on page 3-4 of my user guide:
1 long + 2 short = Video adaptor error
1 long + 3 short = No video card or bad video RAM
high freq beeps while running = Overheated cpu
repeating high/low = cpu problem
repeating (endless loop) = memory error
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
