Question about Dishwashers
Kenmore Dishwasher (model#) 15828691
For the last couple of days, when the dishes are done washing there has been soap left on the dishes. Do you know what some of the causes could be? This is some thing that has never happened before.
    Sergeant:
  • 236 Answers
Possibly too much or too little rinse aid. check the regulator setting in the dispenser
Posted on Feb 16, 2008
Just bought home with Kenmore dishwasher. Know
Do you have the operating instructions for your dishwasher. If not, open the door and there should be a manufacturer's badge on the inside of the door somewhere. Find out what model machine you have. I can help you find a manual online.
A couple of general tips for your info.
  • Wipe or rinse excess food particles from dishes before you stack them in machine.
  • Stack neatly and spaced apart to give better wash results.
  • Make sure dishes and pot handles are clear of the sprinklers. Turn sprinklers by hand and make sure they dont hit against anything.
  • I prefer using dishwashing tablets as they are a measured amount. Best not to use too much soap or powder.
  • If you are using powder, use rinse aid along with it.
  • Dont put your crystals or good wine glasses in the dishwasher.
Hope this helps somewhat.
good luck.
Ash
Oct 23, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
Liduide soap
Hi mansim,
I'm Harvey the Master Plumber.
Your question is: how to use liquid dish soap in the kenmore dishwasher?and which place in dishwasher?
I think it prudent we are first clear on terminology. Based on your discription of your "dish soap", please be certain it says "dishwasher soap". If it doesn't say "dishwasher" on it then it's not meant for your dishwasher.
For a standard american dishwasher the soap goes into a small cmpartment in the door. Just open door fully and you will see the rectangular box on the left. Soap in, then close box. The dishwasher will open it on the second cycle.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Kenmore 15522 Built-in Dishwasher
NOT CLEAN...SOAP LEFT ON DISHES
grab a can of morton salt let it fill and start to wash open the door and throw a hand full of salt into the machine try to hit as much of the tub as you can
start the machine and let it start to wash
and salt again and let it start to wash
hit cancel and let it drain
you may have to repeat this a couple of times but the salt will nutralize the soap and you will not have to buy a new one
Apr 23, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Kenmore ultra wash 665 dishwasher heating element melted down in one corner
I know no other way the heating element could have ended up bent up like this.
Mar 05, 2017 | Dishwashers
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
587 Doesn't work well
AS ABOVE SUGESTION ...PROBUBLY NOT GETTING ENOUGH WATER. NOT LIKELY THE FAULT OF THE DISHWASHER PROBUBLY SEDIMENT FROM THE WATER PLUGED THE INLET SCREEN OF THE FILL VALVE. MANY TIMES THE MOVING OF A FLEXIBLE PLUMBING LINE BRAKES LOOSE ANY SEDIMENT AND DEPOSIT DURING THE INSTALATION OF A NEW DISHWASHER WHICH IS WHY MOST ADVISE REPACING THIS SMALL FLEXIBLE LINE WHEN INSTALLING A NEW DISHWASHER. YOU WILL HAVE TO DIS ASSEMBLE VALVE TO CLEAN SCREEN ...IF YOU BOUGHT THE PROTECTION AGREEMENT OR HAD SEARS INSTALL IT THEY SHOULD COVER A SERVICE CALL TO CLEAN THE VALVE.
Jan 24, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore built in mf#15254
check the sump screen and make sure theres no obstructions.are the wash arm holes clogged?is the drain hose clogged?
Aug 13, 2007 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
200 people viewed this question
Top Dishwashers Experts
