Red screen i have a insigina is-tvhd30 my screen keeps turning red with lines through it
    Problem Solver:
  • 15 Answers
This problem occurs when there is defect in the chroma demodulator circuit. The usual symtom is a red or magenta color rastor with white retrace lines about 3/4' apart through out the display area.
In the worst case scenario, it could also be a defective picture tube. In either case, this is something only a qualified TV repair technician can service.
I hope you still have warranty left on this TV..
Posted on Feb 16, 2008
My Insigina flat TV Screen is showing half purple and half black, what can i do to fix this right
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 01, 2014 | Insignia Brand LCD LED TV remote control...
The power light on my flat panel tv flashes from red to blue repeatedly and will not turn on
check for faulty capacitors on the power board.
thats where to start.look for ones that are buldging at the top or leaking
Mar 24, 2013 | Televison & Video
My screen has blue and red lines across it. Now the red lines are becoming stronger and the screen flashes red until it turns off. how do i fix this?
This is for if the lines are thin and in the form of an arc across the screen.
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
I have an insignia tv, it's an older model and i turned my tv on and now i have this blue screen with a red icon at the top left hand corner and it looks like a lock
Specify your TVs model number. I've to know the model number of your Insigina TV, to give you the method to get it unloked. Send me its model number, which you can see at its back cover label. Send it to me please. OK.
Dec 03, 2010 | Insignia Televison & Video
Don't know code to make remote to operate insigina 14" TV
You just try the following four digit codes. One amoung them will wake your tv up. Proceedings also is given. OK.
[010_ 0189 _0217 _0135
................. 0133 _0116 _0167 _0456_ 0029]
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 07, 2010 | Insignia Televison & Video
Red screen(rear projector tv)
Most likely bad convergence amplifiers. They are soldered in components.They can become intimentent and the lines come and go, usually red or blue.
May 14, 2009 | Televison & Video
Insigina Pilot 4GB
Unit is Bad If its under a year warranty take it to bestbuy and get a replacement although they no longer carry this.
Aug 17, 2008 | Insignia Pilot MP3 Player
No picture
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 30, 2008 | Insignia NS-30HTV 30" TV
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia TVHD30
I, need the exact model no. to see if you can get part for it . need also to know if it uses an external power adapter thanks
Jun 10, 2007 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
