Question about Sharp 32R-S50 32" TV
No channels? I have a 32R-S50 Sharp TV. It is hooked up to a cable wire for basic cable, no box just the wire hook up. When the tv is turned on, it gets the one channel. When you push the remote or the tv channel to change channels up or down, it only goes to Input 1 or Input 2. It never changes from the one channel. I only see the one location to connect the cable wire, so what else would be the problem?
  • Nicky H Feb 19, 2008
    Thank you for the help!
  • Anonymous Feb 29, 2008
    my channels are not programming as they should. It will show the one channel and then I try to change the channel and it goes to input 1 and 2. I tried to find the the ant setup to set to cable but this doesn't exist in the setup menu. Please help!!
  • 33 Answers
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
How much can i sell this tv used
If you are in the US or other area that has only digital signals now, it could only be used with a converter or with some remaining cable and satellite providers. Not worth much-
Mar 17, 2010 | Sharp 32R-S50 32" TV
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Ringing sound on Sharp 32R-S480
Apparently it was in the satelite receiver we disconnected it and reconnected it and sound returned.
Jan 03, 2009 | Sharp 32R-S50 32" TV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Adding Surround Sound to Sharp 32R-S50 32" TV
if the tv has outputs at the back for surround speakers then you can connect it to them..else pass the audio of your TV thru a home theatre surround receiver
Mar 05, 2008 | Sharp 32R-S50 32" TV
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Same channel on all channels
Yeppers it certanly sounds like the tuner control curcuit or the tuner itself is bad. With the back off the set and the tV on, if you tap on the side of the tuner does the set start to work? if so the tuner has to be replaced
Sep 25, 2006 | Sharp 32R-S50 32" TV
Sharp 32R-S50 32" TV Logo
360 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
