Question about GPS
Garmin Nuvi 650
When powered on, the unit turns itself off after a few seconds of operation. Battery is about 1/4 charged, but does not seem to be taking additional charging. Any ideas? Many thanks
  • 9 more comments
  • Anonymous Feb 24, 2008
    Just got a Garmin nuvi 650 and it has exactly the same issue. I haven't charged it yet (it came charged) but it indicates that it has about a quarter of the battery left. It turns off after a few seconds of operation.
  • Anonymous Feb 25, 2008
    The unit shuts down between 5 seconds and 45 seconds of use. This occurs when the unit is connected to the power cord or is being used by battery power. Any ideas?
  • chiliedog3 Mar 05, 2008
    I am having the same problem with both of my Forerunner 201's. The battery does not seem to be holding a charge. It charges but when I unplug it and turn it on, it advises battery low and then shuts off. Any suggestions on fixing this problem?
  • Singa Apr 19, 2008
    I bought a Garmin NĂ¼vi 650 in November 2007. It worked okay untill April 08. I did not use it for a month or so and when I tried to use it it turns off after few seconds it turns on.
  • Anonymous Apr 27, 2008
    I am also having the same issue. I received my Garmin Nuvi 360 about 2 months ago and even when the battery is fully charged, I can turn on the unit and depending on how touchy it is acting, it may turn off as soon as I turn it on or it may boot up all the way and let me search for an address, and then it shuts off. I'm calling Garmin on Monday to see if they've heard of this issue. The unit if fully charged now -- I have 4 green battery bars. Since the unit has no other buttons, I don't know what else to try.
  • kbailey_25 Sep 08, 2008
    My garmin 650 keeps shutting off within a minute of turning it on.... any ideas?
  • gms1975 Dec 09, 2008
    I have the same problem. I can't get it to charge. Every time I turn it on it shuts off within 30 seconds. Can anyone help? gms1975@centurytel.net
  • Anonymous Dec 17, 2008
    Same exact problem here as well!
  • jgarru1 Dec 17, 2008
    Same problem here. Have had the unit for 1 year with no problem until now. This is an overnight problem. All the sudden the unit won't stay on and 1/4 battery charge.
  • backhertz Dec 25, 2008
    My unit has the same problem. I found the unit will take a full charge when plugged into the USB port of my laptop. But when plugged inthe car, the unit is not being powered, but rather runs off the battery for 3 hours & then
    won't stay on for more than 5 seconds.
  • Anonymous Mar 26, 2009
    I'm having the same problem on the nuvi 650 model. It does have some battery charge still on it, but it will not stay on for more than 5 seconds, even if there is a power source directly plugged into it.
    Frustrating!
  • 35 Answers
SOURCE: When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Posted on Jan 21, 2008
SOURCE: Problem with Garmin Nuvi 200
get a tom tom
Posted on Aug 27, 2008
RixsFixes
  • 2200 Answers
SOURCE: Charging Garmin Nuvi battery for first time
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Posted on Jun 21, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin - Nuvi 650 - Touch screen dead/unresponsive
This can be repaired for far less than what you think. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 11, 2009
  • 10 Answers
SOURCE: Replacing battery in Garmin Nuvi 650
I discovered a video on how to replace the Nuvi 650 battery. Hope this helps, Rob
Posted on Mar 23, 2010
The power off
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on.
  4. Contact Garmin Support if this does not solve your problem at www.garmin.com
Jul 04, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
If this fails to solve the problem, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
How do I replace the battery for a garmin nuvi 650
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Dec 12, 2009 | Garmin nuvi 650 GPS Receiver
How do I open Garmin nuvi 650 to replace battery?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Are you sure you have a dad battery?
MAKE SURE to use a Garmin charger!!!!!!
Nov 10, 2009 | Garmin nuvi 650 GPS Receiver
Gps nuvi 250 wont charge, shuts off in a
It will shut off right away if the batteries are not charged.
Why doesn't it charge?
Oct 17, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin Nuvi 650 powers off when connected with car
I had this problem. The problem turned out to be my car charger. Hooking the GPS up to my computer allowed it to charge and operate normally. A new car adapter might fix you right up.
Jul 06, 2009 | Garmin nuvi 650 GPS Receiver
My garmin nuvi turns on for a second then turns back off whats wrong?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jun 10, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
636 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
