Question about Samsung LE46M51B 46 in. LCD Television
Samsung LE46M5 46 in" LCD TV
The screen has gone blank and i can not get a picture at all now. I have had this TV for about 18months.. It just went... Sound is ok, just no picture
  • jennie2524 Oct 07, 2009
    Hi I have a Samsung LE46M51B and the screen just went completely blank but the power and the sound is ok. Cannot even get the menu up. Pleeeease help me :-(
  • Samsung Master
  • 3,714 Answers
Tcon board fault. (screen driver) in the middle at the back of screen. can be the fuse on the board its marked as P. if the fuse is fine then the board has gone it can be the row of brown thick resisters at the top part of the board if they are greasy they have over heated. look for heat marks from the main chip in the board these would need to be replaced. if you need a new or used board to replace there are a few out there but they have been updated. you need to match the part number try to get the same V number but there are so meany V0.0 up V2.5 they will all work the same but they have a few changes in screen control you may not be used to. so try to get the same number.
Posted on Feb 09, 2014
Had same problem same amount of time sent it away came back as a dry solder joint on board cn701
Posted on Mar 22, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
White screen
"White screen" on Samsung LED TV - Forums - CNET
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
SOUND NO PICTURE
Yes your right, THE BACK LIGHT INVERTER BOARD GONE BAD
Oct 17, 2012 | Samsung Televison & Video
Samsung lcd tv 18months old
i had the same problem and it turned out being the panel
Feb 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
NO PICTURE, HELP
You had some buffer ic's fail.Depending on the model these ic's are intergrated into ihe plasma panel.if that is the case,it is cheaper to replace the unit with a new one.
Feb 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Blank Screen
the power supply board has gone bad. part number
BN96-00249A
Oct 19, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Flashing led light
Sounds like the circuit board may need to be replaced. Mine did a similiar thing only my picture turned upside down, screen went blank yet had good voice. Samsung tech said the 2 circuit boards were bad and had to be replaced at a cost of $780 in parts plus labor. I bought a new LCD TV, not Samsung.
Aug 27, 2007 | Toshiba TP50G60 50" Rear Projection...
Samsung LE46M51B 46 in. LCD Television Logo
852 people viewed this question
Henry  Thomas
Henry Thomas
