Question about Estro Barista Athena
Starbucks Estro Barista Athena
I have lost the gray grommet that goes under the stainless steel basket when using the coffee pods. Does anyone know where to purchase one of these?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 296 Answers
Mine is a red O-ring about 2 1/4" diameter, the same as some automotive brake calipers. A well equipped mechanic or parts store like NAPA should have a supply of O-rings with the proper size, best to take your strainer in to test fit.
Posted on Oct 11, 2010
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
We have a stainless steel french press coffee barista from Starbucks, which we purchased in 2003. We need to replace the mesh plunger. Look for options in replacing that part
I have a 2003 press that I love. The mesh plunger works fine, but the little "handle" to push down has broken off. Could you use my plunger to fix yours? I think I'm going to have to buy a whole new one so I don't mind selling you the part.
If so, contact me at emailjunky (at) mac dot com
Jan 05, 2011 | Starbucks Barista Quattro Coffee Maker
I have an old Starbucks Barista Athena Espresso maker. It has worked like a charm until last night. Everything works correctly until I start to brew the espresso. The green light is on and the green light...
I just had my Barista Athena do the same thing. My son took the the coffee basket holder apart, nothing wrong there but the gasket on the bottom inside of the holder, where the coffee basket fits, is compressed letting the basket sit too close to the bottom of the holder. He tested this by raising in the basket and got coffee to flow ever so slightly. I just happened to be looking for a new gasket and saw your post.
It is my understanding that Starbucks is no longer making coffee machines. Your best bet is to contact Starbucks and ask who they may be recommending for repair support.
I hope this helps.
Jan 03, 2011 | Estro Barista Athena
Lights on, motor running, does not do single/double shots
There is a tiny plastic one-way valve in the brass tube on the pump under the top cover that get calcified and stuck when not in use. I used a toothpick to get it out after disassembling the pump and its hoses. Slowly and carefully lay out your parts to reassemble the springs and washers correctly.
Oct 14, 2009 | Estro Barista Athena
Barista Athena won't pull shots
A good pump will fill the tubes in 2 seconds. Lay all your parts slowly and carefully in order during disassembly.
The brass tube with the valve in it unscrews from the angle fitting. Press the little plastic white tab to release rubber motor mount and slide the pump out. Yes it is kind of a technical repair. Unplug unit before starting. I used a toothpick to get the valve out after disassembling the pump and its hoses.
Jul 22, 2009 | Estro Barista Athena
I need a manual for the Starbucks Athena Barista - how can I get one?
I believe this is the URL you want:
http://www.starbucks.com/ourcoffees/Barista_Final_011305.pdf
Jan 11, 2009 | Estro Barista Athena
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Estro Barista Athena Tripping the GFI Circuit
is there a diagram for the coffee holder. i took mine apart to clean it and i am not sure how the spring goes in.
Mar 04, 2008 | Estro Barista Athena
Estro Barista Athena Logo
241 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
