Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
Usb not working
I thnk pin set up problem or somethng
    Master:
  • 518 Answers
What does USB have to do with this drive? Is it external?
If not, did you set the Master/Slave jumper on the back correctly?
Geno
Posted on Feb 17, 2008
My phone cant power on even though i re set it. i thnk it has a virus .
try to connect it to a pc using a usb cable. remove the battery
Dec 02, 2013 | Alcatel OT880 Cell Phone
Can't find the second set of pins for my USB drive
According to the manual, if you have front panel USB, use the pin set labeled USB3 for these connections. The USB3 connector is located between PCI slot 1 and 2. If you are already using this for the connector labeled 1394....1394 is for FIREWIRE interface and this mainboard does not appear to support it. Be careful of that connection unless you are absolutely sure of yourself.
Dec 25, 2011 | EliteGroup K7VTA3 V6.0 (K7VTA3_V6.0)...
Its says to close front cover but it is already closed. I have opened and closed it many times with no change in result
GENERALLY THERE IS A PIN ON THE FRONT DOOR THAT BREAKS AND WILL NOT TRIGGER THE SWITCH TELLING THE COPIER THAT THE DOOR IS CLOSED. yOU WILL HAVE TO LOOK VERY CAREFULLY AT THE MACHINE WITH THE DOOR OPEN AND LOOK FOR AN OPENING THAT WOULD ALLOW AN ACTUATOR OR PIN TO GO IN ( USUALLY LOOKS LIKE A SLOT). TAKE AND PUSH INWARD WITH A NAIL FILE OR SOMETHING OF THE SORT WITH THE MACHINE ON AND IF THIS IS THE PROBLEM, THE MACHINE WILL POWER UP. SUPERGLUE SOMETHNG IN PLACE TO SUBSTITUTE FOR THE PIN ON THE DOOR. GOD BLESS, HOPE THIS HELPS.
Nov 06, 2010 | Toshiba 2860 Copier
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to retrevo.com and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
Oct 06, 2009 | Soyo P4X400 Dragon Lite (P4X400DRAGNLITE)...
Psp-7000x not loading on pc says does not support this platform 7
You can get the Samsung Pleomax 7000x USB Speakers to work with windows 7 32/64bit by downloading and installing the latest driver from Pleomax.com then download and install and the C-Media CM-102 Windows 7 Driver from X-DRIVERS.COM .
Sep 02, 2009 | Samsung Pleomax Crystal PSP-7000X Computer...
Aaaaaaaaargh! i have a webcam, i THNK its a nikon webcam, but im not sure.... and i have lost the installation disk :( please help me, i dont know how to install it -_- :D thank you
FISRT U MUST CONFORM THAT UR WEB CAM IS IN USB MODE. MOSTLY IT WILL BE USB.
IF S, U TYPE USB NIKON WEBCAM SOFTWARE DOWNLOAD IN GOOGLE SEARCH AND DOWNLOAD IT FROM THE SITE.
THEN , INSTALL IT IN UR COMPUTER.....
Nov 28, 2008 | Logitech QuickCam Communicate STX Personal...
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Usb port does not work
ok, first of all the zen needs windows xp with service pack 2 to work with your pc, if your windows does not have service pack 2 , the usb port will not work with it.
Aug 20, 2006 | Creative Labs Zen MicroPhoto MP3 Player
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
41 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
