Question about Kenmore 43042 Front Load Washer
Washer's tub will not move
I have a Kenmore Front Load Washer model 417-44082400.
The tub moves freely by hand but will not run on it's own. I have used the diagnostic feature and get an E5E error code on the display. I have replaced both the motor control board and the main control board and according to the chart the motor ohms out correctly too. It still gives me the same error code and I am stumped. Ohmed the cables leading from the control board to the motor control board and they checked ok. You can hear a relay click when the tub is suppose to move but get nothing. Any help would be much appreciated.
  • mpeels Feb 22, 2008
    Thanks for the help. Problem has been solved. Problem was in communication cable.
  • Gary Davd
    Gary Davd May 11, 2010
    IS this a US model unit?? Where did you buy it ??
  • 96 Answers
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Posted on Feb 17, 2008
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have checked all recomended trouble shooting suggestions- there must be more?ot drain or spin, motor running, all lines have free flow of water, nothing between tubs and pump pulley moves freely. can
although the pump will turn by hand . when you use the motor power and the belt tenson;. it may be binding. ( this has been a common problem. ) ck for play in pump shaft and look for black under washer from belt fraying . my guess is the pump and also replace belt with the pump // hope this helps. **** and thanks for using fix ya ..
May 04, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Good Morning !!! Does the tub move sided to side
Yes, the tub should move freely as you describe. The suspension doesn't rely on guide rails, but rather, on four suspension balls and rods. The unit should not have been moved horizontally because the suspension could be disengaged, but you may be ok. I would just level the machine properly and run a load in it. If the suspension has come apart, you'll definitely know it because the machine will bang loudly and try to "walk" across the floor. If that happens, respond back and I'll try to help you open the machine and fix it.
Good luck.
Feb 19, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite HE 3 model #110 4822 201 will not spin. It runs through an entire cycle and fills and drains. The drum will turn a few turns clockwise when spun by hand but then will not move further...
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 15, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
While finishing a load of laundry, during the final spin/rinse cycle the washer made an aweful pounding and banging noise. It was so loud I heard it from the other side of the house and went running to see...
Yes I do know unfortunely the basket support broke. This support is mounted on to the back of the basket and goes through the rear bearing and the back half of the outer tub. This is a very extensive repair .the unit has to be totally disassembled ,if it only broke the support it is about 100.00 , but if the rear tub bearing is also damaged you may consider replacing the unit with a new one either way this is an expensive and extensive repair...
Sep 17, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine shakes badly during spin cycle. I have to shut it down and have not been able to use it. It's almost like the load is totally unbalanced. I have tried small loads, medium load and even...
If you have moved it recently there were some Kenmore washers that had pins on the tub underneath that fit into sort of cups. I leaned mine over and didn't get them back into place and it shook like a earthquake . There are some machines with bumpers underneath that keep the tub from moving too far to the sides. See if you can move the tub by hand side to side on all four directions to check movement. Go online and check your model for recalls, consumer complaints, world of wealth on the net.
Nov 27, 2017 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
May 03, 2009 | Kenmore 24632 Top Load Washer
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 43042 Front Load Washer Logo
544 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
