Furnace blowers continues to run after reaching correct temp . this is a york heat pump and electric furnace. i can see the mercury switch on thermostat never breaks contact unless i lower setting more. Contactor
on heat pump has been replaced. Could this be a problem with the thermostat or a temp sensor in the furnace
It actually sounds like you may have answered the question yourself. If the mercury isn't breaking contact, then obviously it's still calling for more heat. This is a common problem with the old mercury thermostats and are usually replaced with digital ones that are way more accurate. The are fairly cheap at Wal-Mart and such, and replacing one is basically all color coded.
