Question about Dryers
LG Tromm Electric Dryer
Hey just a quick question, the coating on the drum of my LG Tromm Dryer is comming off, is that normal wear and tear after 6 or 7 months in use? I've never seen a dryer drum do that.
  • 3 more comments
  • Pitchy25 Feb 17, 2008
    Thank you Master_Tech, I just wanted to make sure because the service tech that came to change the drum was trying to tell me that it was normal wear and tear. He was quite upset that he had to come and change and this just proves my point!! Once again Thank-you!!
  • CornDaddy May 16, 2008
    I am experiencing the same problem with my LG tromm gas dryer after less than 1 yr of use. We dry a lot of baby clothes that have buttons on them but this has to be considered normal use. Anyway, we are having Sears come check it out since it is under warranty.
    I will update with the result...
  • Anonymous Mar 22, 2014
    drum turns slow. has hard time starting turns for a few minutes and then shuts off.
  • kris w barker
    kris w barker Sep 04, 2014
    vent got cloged now heat no longer works
  • 770 Answers
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
Posted on Feb 16, 2008
  • Gary Davd
    Gary Davd Feb 17, 2008
    Sometimes they do make lemon parts
    glad u got it replaced
How do you get lg tromm dryer belt around drum and idler pulley
Lisa, Check the attached links, video shows how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Belt Replacement LG Electric Dryer Repair Part 4400EL2001A
How to Change the Drive Belt on an LG Dryer DLG3788W
Mar 08, 2016 | LG Dryers
DRYER MAKES CLUNKING SOUND WHEN STARTED.ALL ELSE IS FINE
Bad drum wheel. Easy to replace. Check video out at appliancepartspros.com
Feb 21, 2015 | LG Tromm Electric Dryer
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Where is the sensor located on a lg tromm elect dryer
The moisture sensor is located in front grill area inside the dryer. If you look inside the drum where the filter screen mesh is, you will find 2 curved metal bars. Those are your moisture sensors.
Hope this helps.
Nov 06, 2011 | LG DLE5977 Electric Dryer
I have a LG Tromm DL62524W my dryer no longer is getting any heat , and on the settings it says its on the cooling setting and I tried to change the settings.
It's possible that the high limit switch has failed and needs to be replaced. You will need to tear down the machine to get to it.
Good luck
Jun 16, 2011 | LG DLE2532W Electric Dryer
I have an LG DLE3777W electic dryer that was making a sqeeking noise but is now making a banging and vibrating noise. I think the bearings are gone. I do not have a prts manual so I do not know what to...
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
I don't know how quickly you need the parts, but on eBay they are cheaper:
http://shop.ebay.com/i.html?_nkw=dryer+drum+rollers+&_sacat=0&_odkw=dryer+drum+rollers+and+glides&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope this Helped Tim
Jan 18, 2011 | LG DLE3777 Electric Dryer
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
Loud thumping noise has resulted in penny size hole in the drum.
Check your owner manual some LG had life time warranty on there drums..if so call for service..
Sep 21, 2009 | LG DLE3777 Electric Dryer
LG Tromm Dryer Thumps when running
The drum on my dryer is cracked, it thumps the entire time it runs, and it snags up all of my wife's clothes. We hate these appliances!
Aug 14, 2009 | LG DLE2514 Electric Dryer
Dryers Logo
362 people viewed this question
Top Dryers Experts
Marvin
Marvin
