You have a problem with our fuser assembly - located where you pull out the left printer door - it is the very hot assembly where the paper leaves the machine - it will either have a yellow or black felt cover. Only two screws hold this unit in - one at the back and one in the font. Take this unit out and look for trapped paper in the rollers that could also cause the fuser temperature readings to be incorrect. If you cannot find any paper, reset the code in service mode and turn the machine off/on. If the problem returns as you power on - you will need a new fuser unit. To clear the fuser error enter service mode as follows:
Press the head key (head shape with star inside) - 2 and 8 at the exact same time - then HEAD key again. You should now be in service mode. Now - COPIER - FUNCTON - CLEAR - ERR - OK. Then turn off the power and on again - this may cure your problem indefinetly or definetly. But even if you find paper in the fuser, you mUST perform the CLEAR procedure or the error code will not go away. Good luck.
I have a canon image runner 5000.how i can translate french language to english languaga....tnx
SOURCE: I have a Canon Image Runner 1670F
E000 is a printer reset code. Scroll through the menu and do a clear on it. should be ok
SOURCE: Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
