Question about RCA G32665 32" TV
How Do I Get a DVD to Work with This TV?
I plugged my DVD player into the 3 inputs on the back of the TV. No DVD picture. I am using a DVR + cable TV in. What am I missing
  • 7 more comments
  • WSC3 Feb 17, 2008
    Yep, I did that. I used the remote and pressed "DVD", which set the TV to channel 3, which momentarily displays "3" on the screen. (I had previously checked the TV SetUp menu and made sure that DVD=channel 3.) But, channel 3 is displayed blank. I can't help but wonder if the incoming cable feed plugged into the TV and then feeding out of the TV into the cable DVR doesn't have some effect here. Would that override all input to the TV, even from the DVD? BTW, in setting up the DVD/VCR, I go from "out" on the DVD to "in" on the back of the TV. What am am I missing?
  • WSC3 Feb 17, 2008
    EFriend,
    Okay, maybe I don't understand your advice clearly. I set it to "DVD" mode, but is that the same as "Video" mode? What other mode is there but video mode? What do I press on the remote for video mode? How do I tell if I'm in video mode or not?
    Sorry for the confusion.
    Thx.
  • WSC3 Feb 19, 2008
    Thanks! How do I put the TV in video mode? What option does that? I pressed "DVD" on the remote, but apparently that does not put me in video mode. (I only seem to have one set of video inputs on the back of the TV.) How do I put it in video mode? Why wouldn't the "DVD" button on the remote take care of that?
    Thanks.
  • WSC3 Feb 21, 2008
    It's the original remote that came with the TV. It's an RCA as well.
  • WSC3 Feb 22, 2008
    Oh, and how do I change it back to "tuner" mode?
    Thanks!
    WSC
  • WSC3 Feb 23, 2008
    I found video mode! I get an on-screen error on the TV during video mode that says: "Unusable signal." What on earth does that mean? This is my Dad's TV, but I used to have one very similar (a little older, actually), and it would work with a DVD....
  • WSC3 Feb 27, 2008
    I selected the input button on the remote and the TV displayed the words "VIDEO" which I'm assuming indicates video mode. The message on the screen from the DVD says "Unusable signal." What does that mean?
    Thx.
  • WSC3 Feb 27, 2008
    Yeah, I checked the cables. If I had just one channel off or no video but audio, I'd buy into the "cables are bad" argument. Is the RF modulator the round cable connector?? Or is it patch cords on one end (for the DVD) and, what, coax on the other end? Can I get this anywhere or is it a Radio Shack only item?
    Thx.
  • WSC3 Mar 01, 2008
    Ok. I went over and looked at the TV again. His Comcast DVR is plugged from his antenna port on his TV into the RF on the DVR. Is this hijacking all signals so that the DVD will not work?
My problem audio input and out put work good
video input and out put there is no picture
what is the problem?
dvd player is to check with what & how
Posted on Mar 16, 2008
Sorry, just got back from vacation..
Hummmm...
Bottom line; I don't believe that your TV is in the Video mode...
Since I do not know what buttons are there on your remote control; Here is what I recommend,
The remote has to have either of these three buttons.
1. AUX (Auxillary Input)
2. INPUT (Input selection)
3. Antenna {Switches between different Antenna (or this case input) source}.
One of these buttons has to carry the Tuner/Video change over function. Try playing with them to see which button will turn on the DVD input connected to your TV.
Good Luck!
Posted on Feb 27, 2008
    Problem Solver:
  • 15 Answers
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Posted on Feb 16, 2008
  • 4 more comments
  • Edward Yoo
    Edward Yoo Feb 18, 2008
    Ok, I think I understand your problem.
    Since your cable signal and DVR is coax based (tuner mode) and using channel 3 to view, you do not have to concern about any signal mixup.
    Make sure you are not in tuner mode. The very fact that you see the channel 3 displayed for moment indicates you are indeed in the tuner mode. Again, you have to set the TV in the Video mode..
    For example, depends upon how many video inputs you have on your particular TV, let say, that you connected the in coming cables from dvd player to video1 on the back of TV, make sure the Tuner/Video mode is set to Video1 and not video2 or any other mode..
  • Edward Yoo
    Edward Yoo Feb 21, 2008
    Usually depends on the brand, the remote has input or Video button to change the tuner mode. You said it has a DVD button on your remote.. Is this remote control an original one that came with your TV or is it a generic replacement (universal) remote?
    Please tell me what kind of remote control you have..
    Pressing DVD button on your remote means you're gaining contol of your DVD player and not your TV; so it has nothing to do with changing the input signals through the back of the TV...
  • Edward Yoo
    Edward Yoo Feb 27, 2008
    Ooops,
    just posted the last comment without being logged in.
    I hope you that will fix your DVD nightmare..^^
  • Edward Yoo
    Well, 'unusable signal' means either the cable feeding the signal is bad or, it is not connected properly. Double check the connection ends. make sure that video out (yellow tip) from DVD is plugged into Video in (yellow) on the TV and same for the audio left and right channel (red and black) on both ends..
    If none of these are the culprit, then I would have to say it is your TV's Video input stagej ust not working..
  • Edward Yoo
    If the RCA input terminals are defective only other way you can connect and view DVD player is to use a RF modulator.
    The RF Modulator connects between the DVD Player and a TV.
    outputs from the DVD connects to RF Modulator then the feed connects through coax (screw in) antenna terminal.
    The RF modulator usually costs about $30.
    That's all the suggestions I have.
    Good Luck!
  • Edward Yoo
    Edward Yoo Feb 29, 2008
    Here is a block diagram of how to connect a RF Modulator between TV and DVD player.
    You can get one from Radioshack, Bestbuy or other stores..
    Just connect the RF modulator and set your TV to channel 3 to view.
    I think you have the cable box connected your TV antenna feed
    so, you might need to purchase a A/B switch box as well.
    Ultimately, you would connect DVD feed to A and cable box feed to B.
Connect AV receiver to a Dish receiver model VIP722 DVR
Your DVD player should connect to your TV, not the DISH DVR. Is the Yamaha some sort of receiver or something similar? If so, it should plug into the TV as well. The DVR just provides a signal to your TV, just like the other two components. On the back of your TV there should be other connections to plug into like HDMI1, HDMI2, AUX1, etc. You select which input you want to view using your TV remote. For example, if you were watching a DVD, you turn on the DVD player. Say it was plugged into AV1 or something similar on the back of the TV. With your TV remote, select which input you are using...that way your TV receives the signal from your DVD player and nothing else.
Nov 16, 2017 | Onkyo HTR500 Receiver
DVD-VR357 RECORDS VIDEO (FROM VIDEO1) FROM COX DVR, BUT NO AUDIO
well there the first thing i would check is the audio connection..
basically if you are recording from a playing media, like a dvf player
it would be like this
audio and video out from the dvd player to the inputs in the recorder.. then the out puts from the recorder to the input in the tv... (just a refrence)
upload your diagram, and state exactly what you want to record from.. if its the tv or another media type..
If its from the tv,, lets say you got cable and you want to record from cable,, Its
connect the out put from the cable box to the input of the dvr, then the out from the dvr to the input of the tv..
or
if its from an arial
connect the arial to the dvr,, now connect the dvr to the tv,, I guess you got the picture of what i am saying..
Basically all the out put from the media you wish to record from to the DVR and then from the DVR to the Tv..
Feb 22, 2008 | Samsung DVD-VR357
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Cyberhome DVR 1600
First thing to check is to plug it into a different TV set if you have access to one. If still not working, then suspect the cable or the DVD player/recorder itself. If it works fine on another tv then all depends on which input you have it plugged into on your main set - get the right cables to try plugging it into a different input on the tv (post back with the TV make and model and the details of which input and which cable type you are using if you need help with this). If you have cable or satellite or another DVD/VCR/PC - do they work on the TV? on different inputs. If not then the problem is either the TV or possibly the TV settings. How are you trying to send an e-mail? perhaps with some details we can help. Hope this helps :)
Aug 06, 2007 | Cyberhome DVD Recorder - DVR1600
How do i connect dvr to dvd to tv?
I assume the dvd is a player/recorder. So the dvd and dvr are both recording devices. You can take the outputs of cable box into the inputs of dvr. Then the outputs of dvr into inputs of dvd. Outputs of dvd into tv. It will be combersum to use that way but it will work. I would have to know what you were trying to accomplish to recomment the best setup.
Jan 16, 2009 | Televison & Video
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
New TV hookup
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
RCA G32665 32" TV Logo
491 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
