Question about Whirlpool LER5636P Electric Dryer
Testing dryer motor
I think my dryer motor is going out but I would like to test it for before I purchase a new motor. How can I test my motor to see if it is the problem?
  • Gary Davd
    Gary Davd May 11, 2010
    do you have a meter??
    Genius:
  • 1,036 Answers
Hi there!
Very often you don't need a whole new motor. The parts that wear are called brushes, and are made of solid graphite.
These supply the power to the rotating part of the motor.
If the motor sticks or sparks, then these are probably what is needed.
If it buzzes a lot or has very little power, it is more likely to be the run capacitor.
Have a look at this site for detailed pictures of the parts, and replacement costs (from them) It may be better to shop around or enquire locally for replacements.
http://www.repairclinic.com/
Repairs should only be undertaken by competent persons or those trained in repair procedures to avoid injury.
Posted on Jun 22, 2008
Clothes dryer blows thermal limiter. Replaced and worked perfect for three days, then blew again.
I appreciate your post, David!
Based off the information you have provided your Frigidaire dryer is blowing the thermal limiter and you think the problem could be with the motor or heating element. In order to pinpoint the problem with your dryer I would suggest seeking assistance from a professional technician. They will have the appropriate tools needed for test each component and this will help prevent you from purchasing unnecessary parts. I hope this information is helpful. -Matt
May 28, 2015 | Frigidaire Dryers
My convertible top don't operate can you help
I own a 1997 Cavalier, but it is not a convertible. I would definitely start with the fuses. Remember that all motors have to be protected by fuses from overloads. If you get lucky and it is the fuse, then do yourself a favor and lubricate the moving parts with some WD-40. If it is not the fuse, then there is a chance that it could be the motor. Hopefully it is the simple fuse. The motor could be tested on a bench top with a car battery before purchasing a new one. You need only provide 12 volts from the positive post of the battery and provide a connection of ground from the negative post of the battery. If of course the motor does not function, you will not be risking as much by first testing the motor before making a purchase. I would think that most part stores may offer to test the motor for you once it is dismounted from the vehicle. Good luck. Hope it is the fuse. One last thing to consider is to test the positive wire going to the motor to ensure that you have power going to the motor which would indicate a working fuse. Naturally you have to have a 12 volt test light to test the fuses and the power going to the positive on the motor.
Jun 04, 2014 | 1997 Chevrolet Cavalier
Whirlpool Duet Dryer, Drum doesn't turn
repairs should be performed by an authorized repair person. check the thermal fuse located on the blower housing. unplug the dryer and locate the thermal fuse and perform a continuity check. more than likely it is open, replace it.
Jun 03, 2017 | Dryers
Whirlpool Dryer Motor 3395652
What is the complete model number of your unit?
Dec 03, 2012 | Kenmore 3976707 3395652 Whirlpool Dryer...
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
dryer_door-switch.jpg Door Switch
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
dryer_start-switch.jpg Start Switch
A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
dryer_thermal-fuse.jpg Thermal Fuse
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
dryer_thermostat.jpg Thermostat
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
dryer_timer.jpg Timer Motor
Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
dryer_motor.jpg Motor
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
Jan 23, 2011 | Dryers
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
Motor smells on model lde7314ace
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
WHIRLPOOL DRYER WON'T START
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
1,580 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
