Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Grany picture , all colors have ghoast. cannot adjust gousing. no sound.
I have no funds totake this into the shop but i have a multimerter and i know howto use it. is there ankything yooou can sukggest that i can fix.
  • partnerdude1 Feb 19, 2008
    what a bunch of crooks. you email me pretending to have a fix for me and said click here. when i did all i got was --
    TRY OUR PREMIUM ASSISTANCE PLAN. OF COURSE FOR $$$$$$$$$$$. I WAS LED TO BELIEVE THISHELP WOULD BE FREE. THANKS BUT NO THANKS. NO SUKCKER LIVES HERE.
  • 8,596 Answers
If you are using an HDMI cable, switch to Component cables or get a firmware upgrade from the Philips website.
Posted on Feb 19, 2008
  • Corey Knoettgen
    Corey Knoettgen Feb 19, 2008
    When you ask for free advice, then you get what you pay for. Did you even try my solution before you rated my solution as inappropriate. I do not work for FixYa, and I did not solicit any funds from you, pal.
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Green picture
Possible needs color tracking adjustment done by shop.
Apr 18, 2010 | Samsung HLN437W 43" Rear Projection HDTV
Very blurry picture all of a sudden
sounds like you convergence generator is gone out, when this happens it is common for one or more of the colors to go out of alignment and not able to adjust, or hold the adjustment. typical cost for this type of repair at a shop is $250-450
Mar 27, 2010 | Panasonic PT-53WXD63 53 in. Rear...
No sound, no picture following a mini explosion in the rear
yes it can be repaired, the y-sus and z-sus boards are most likely bad. would require a qualified shop to repair it as there are adjustments to be made to the new boards.
Jul 22, 2009 | Televison & Video
Distored and grany picture
it is a CCD failure try to contact Sanyo they might change it free of charge as other companys are also doing it is a manufacturing fault in CCD units see the link try it email them i am sure they will do it free of charge
http://www.imaging-resource.com/badccds.html
tell me ur region i will fwd u a link for support
pls rate me FIXYA for help
Feb 27, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Picture very dark
try to adjust the screen at the back of the plyback.a big parts inside the tv with a wire attach to the picture tube. thre's a two knob there, the lower knob try to adjust it
Oct 09, 2008 | Sylvania 6432GG 32" TV
KV-36XBR450 CANNOT ADJUST COLOR
This sounds like you might of lost one of the colors of the crt. I would suggest that you take to a repair shop.
Jun 27, 2008 | Sony KV-36XBR450 36" TV
Poor picture, raster & sounds ok
If the picture is fuzzy (out of focus) it may have a focus adjustment on the flyback transformer. Possibly an adjustment available from the outside, through the back. Look for any markings on the plastic housing indicating Focus, Brightness etc.. You can use a small screwdriver through the labeled holes in the case to make adjustments.
If the picture is crisp, but faint or the colors seem washed out it may be the tube is at it's end of life or needs to be rejuvenated. TV shops can rejuvenate tubes but it's not cheap.
Mar 11, 2008 | Konka K2386U 23" TV
Red picture
sounds like u may have a picture tube problem/CRT, would be high price repair
Oct 27, 2007 | Zenith A25B33W 25" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
