Question about Averatec C3500 Tablet PC
Keyboard issue One of my keys cane off and I cannot get it to snap back on. How can I fix that?
  • jpg123 Feb 16, 2008
    I has a snap feature with a piece am having a hard time giving information because I need the bad key to do so.
    That is the issue. Knowing how to snap it without breaking something.
    Genius:
  • 3,587 Answers
Well..each keyboard has a different mechanical strategy for how it's attached. Look under the bottom of the key that came off, and you'll see either a two hinged metal flange or a snap on insert approach. The two hinged deal takes a small blade screwdriver, and a pair of needle nose pliers, and a ton of patience to get it right, and ensure that the metal ears don't get destroyed.
the snap on insert version is simpler,
Tell me which you have and then we can proceed.
Posted on Feb 16, 2008
  • Patrick Michaels
    Patrick Michaels Feb 16, 2008
    ok..you'll need to turn off the computer to do this. power down, and then gently, press the key firmly and straight down, and aligned like the others. The key will 'feel the head' of the keypad, and settle in. IF you get any resistance at all, back the pressure off, and try it again. Patience is most important here.
  • Patrick Michaels
    Patrick Michaels Feb 17, 2008
    the big question..did it work for you? Thanks for the vote.
    got backup?
    President:
  • 1,944 Answers
Check that nothing has broken under the key or on the space where it's supposed to sit (on the unit). Usually keys should just simply snap on.
  • Damen Wong
    Damen Wong Feb 16, 2008
    Of course you would need to find the right way to snap it back on if you see nothing is broken.
My Anker keyboard won't stay connected to my ipad, and it has stopped working after connecting tomy
Hey...umm sorry about your keyboard not working..What i cant sae is maybe u have a stickey key.
To fix this!
Replace the key on the keyboard.
Wipe off the key if you have maybe spilled somthing on it.
Jul 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Tablet onscreen keyboard keeps reversing capslock.
Hi Melissa
When does this happen? Hitting Return/Enter/or the
key will generally throw this up. It is also noticeable on spreadsheets which jump to the next specified cell and automatically create a leading upper case character in the cell just used. These are operating system or program settings.
Try noting when this happens and then re-create it to be sure. Log the sequence to see if there are any keys which are involved (also the length of time or even just tapping a key or spot on the tablet surface can have a totally different meaning)
Hope this helps....
May 19, 2014 | Tablets & eReaders
My tablet keeps coming with with " Android Keyboard is unfortuntally not working". Gives the OK prompt. Also I am having problems accessing some of my games. Cane you help me please?
My brother & myself were never able to resolve the issues with the M752B tablet.So, I mailed it back to the company I was told to, in hopes that they will be able to fix the problems. The telephone # they gave me for help is 1-866-777-0079 or 1-607-257-7279. Be prepared for a long wait time. They also gave me an address to mail the unit back if I failed in the fix. That address is
Attn:R92260
Global Phoenis Computer, T&S
21 Dutch Mill Rd.
Ithaca, NY 14850
Good luck, Brian
Apr 29, 2014 | Kocaso M752B Dual Camera Android 4.0 OS 7"...
Keyboard key popped off
The key should pop back on... if it doesn't then the brackets on the keyboard for that specific key are broken. The keyboard will still function properly... every key will work fine.
Or buy a new keyboard.. they are cheap.
Sep 08, 2009 | IBM Tablets & eReaders
Some of the keys in the keyboard does not work
Dear Sir,
If you are having laptop assembly &disassembly knowledge you can try to fix this problem.First take out the keybord pad,t hen take out the all the screws and keys of keyboard clean the dust particle present inside the keypad.Then reassemble the keybord connect it to the laptop,check it.if not solves your problem solution is you have to buy keypad for your model.if you find any difficulty to resolve this issue post a comment,we will glad to assist you.
good luck
Aug 27, 2009 | Fujitsu LifeBook T4210 Tablet PC
Apostrophes key in laptop keyboard is not working, how do I fix it?
It's possible there is a mechanical problem with that key (broken, dirty).
But just in case you also use a usb keyboard with the laptop make sure that you did not disconnect (the usb keyboard) with the number lock engaged. If so you can either use the virtual keyboard to disengage the number lock or reconnect the usb keyboard and disengage the number lock. Then check if the problem is fixed when the usb keyboard is disconnected.
Jul 09, 2009 | Tablets & eReaders
KeyboaRD ISSUES
replace your keyboard if possible
May 08, 2008 | Toshiba Portege 3500 Tablet PC
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Viewsonic Tablet PC keyboard issue.
may be the best solution for this problem is consult your hardware manufacturer and ask him to replace the motherboard, if the pc is under warranty they will replace it for free of cost.
Apr 05, 2007 | ViewSonic TPCV1250S (TPCV1250S0103) Tablet...
Averatec C3500 Tablet PC Logo
97 people viewed this question
Top Averatec Tablets & eReaders Experts
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
