Question about Abit KN8 Ultra Motherboard
Alarm sounds on PC when using FS2004
When using FS2004 an alarm inside the PC operates, on exiting, this alarm stops.
Many thanks Colin
  • carcol Feb 17, 2008
    Yes only when using FS. Windows XP Svc Pk 2. 1GB. DIMMS 4. Graphics Card Radeonx800 GTO. The alarm is one long tone which stops after exiting the Sim. Many thanks
    Carcol
    President:
  • 2,351 Answers
Does this alarm go off while playing Flight Simulator 2004?
Please include your operating system Ex: Win XP home, PRo . How much memory is in your system? How many dimms, 1,2,3,4?
What video card do you use, Ex: PCIE ATI Radeon 256Mb 9500?
Can you describe the alarm a bit better. A long beep with short beep, repeating untill the system shuts off?
Answer these question so I can narrow down the what may be troubling your Pc.
Posted on Feb 16, 2008
  • Mike Peluso
    Mike Peluso Feb 20, 2008
    Your system is above average for the game. So what I'm thinking is the card might be overheating (which it shouldn't be). Your video card has 4 times the power than what is needed to play.
    Looking through your manual I found a section related to a FAN Fail Alarm Selectable. pg. 3.8 PC Health Status. So here is what I'm thinking. Remove the side panel from your Pc exposing the motherboard. Fire up FS and when you hear the alarm get your butt over to the guts of the pc & listen to where that alarm might be coming from. I'm betting it's the internal speaker which is the bios telling you one of the fans & it might be the CPU fan is failing. When you quit the game the alarm stops.
    Pg.3-24 CPU Warning Temperature:
    This item lets you select the temperature at which you want the system to send out a warning message to the PC speakers of when the temperature goes beyond either limit. Leave the settings where they are but write them down so you know where they are set. (incase you change them). Got to admitt you have a great bios in that board. Honestly you & your manual need a little time together. I think your answer for a fix is in the manual. If I had your board & could trouble shoot it, this is where I would start. I can only suggest a fix. I can't do anything else. So you know where to look Mr. Colin It wouldn't hurt to clean the video card fan........ Good hunting! Post back...
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
I disconnected battery cables on small suv to clean them. After reattaching, I noticed rear window on tailgate went down about 8 inches. I then raised window by button on dash. It closed for a moment and...
its lost its memory ,hold key in lock and close window then holding key in closed position for 10 secs should reset the memory in the electronic control box on the window motor memory inside this control box
Dec 19, 2011 | 2002 Land Rover Freelander
Hello, my factory alarm on my 2008 Acadia, "goes off" randomly when the truyck is locked usually within 30 minutes of exiting the vehicle. Even if I lock the truck from inside. Upon entering the...
sounds as if the hood sensor is loose/hood itself has loose bolts- check all mounting points near hinges- try and find the plunger switch for you alarm and see if it is loose or needs to be adjusted.
sound as if after you engine compartment cools off after driving the hood is shifting enough to trip the alarm
May 25, 2011 | GMC Acadia Cars & Trucks
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
Alarm is sounding
replace the memory card of your computer.
Feb 27, 2010 | E-Machines eMachines Desktop PC
How to set factory alarm without remote, togle switch enabled
factory alarms are passive, if it is working it sets itself when u exit the car. u don't need the remote for the alarm to work if it has a factory system. if u want to test if it is working lock the car with the power lock button and leave the window down, reach inside the car and open the door from the inside handle, the alarm will sound if it is working, to disarm just lock and unlock driver door with the key..
May 31, 2009 | 1993 Nissan Pathfinder
Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
Dec 25, 2008 | 1998 Volvo S70
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
2) Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
How to set alarm and ring with radio?
Hi gidgid.
This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
1. Press [ALARM] to switch to display the alarm setting.
2. Select ALARM 1 or ALARM 2 using [ALARM].
3. Press and hold [ALARM] for two seconds.
4. Use VOLUME [ + ] / [ - ] to enter the hours.
5. Press [ALARM].
6. Use VOLUME [ + ] / [ - ] to enter the minutes.
7. Press [ALARM].
8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
ALARM is selected, a two-minute crescendo alarm will be
emitted at the set time when the alarm is active. If RADIO is
chosen, the radio will be turned on for two hours at the set time
instead.
9. If RADIO is chosen, use [STATION] to choose the radio
station and press [AM / FM] to select AM or FM.
10. Press [ALARM].
11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
12. Press [ALARM] to exit.
Note: If there is no battery for the radio, there is no operation for
step 9 ~ 11.
sleepy head
Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
Abit KN8 Ultra Motherboard Logo
212 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
