Question about HP Photosmart C3150 Printer
Black ink does not print
First issue was printer not printing at all but there were no error messages. I did all the suggested routine things from HP including reloading software, maintenance checks, printing self-test pages, cleaning contacts etc I have put new ink cartridges in place It will print a document if it is in colour but will not print it in black. I just replaced my black ink cartridge and it will scan and print black but cannot copy or print black from computer
  • 1 more comment
  • Anonymous Mar 18, 2014
    only prints in black ink-but will make copies in color. How can I get it to print in color?
  • Anonymous Mar 23, 2014
    printer has the ! on and will not print, says problem with black ink
  • Anonymous Mar 31, 2014
    Black and white printing is often faded or misses lines completely. Tried a head clean, test page and put in new black cartridge all to no effect.
  • 3 Answers
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls
Posted on Apr 02, 2008
2 Suggested Answers
SOURCE: black ink does not print
This is quite a common problem for these models, particulary with the black not printing, to check if this is your issue print a self test page, then try a cleaning process through the tools menu if you are still not getting any black print you have the classic blocked nozzle/ airlocked printhead issue, it is most commonly seen in printers that have used aftermarket black ink at some stage and/or have been sitting unused for a while.
try the following
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
if this doesn't work the only way to clear it is to disassemble it and soak the bottom of the printhead in hot water then reassemble and clean the head
good luck
PS it only seems to be a problem with black refilled/aftermarket cartridges, haven't seen any probs with any of the colour refills
Posted on Jun 03, 2008
My hp envy 5530 is only printing half a picture
If it is only printing the top half then it is quite possible you are running out of ink. Try printing on only black and see if this works. When is the last time you replaced the colour cartridge?
Feb 25, 2015 | HP ENVY 5530 e-All-in-One with 2-month...
Blue ink won't print
The cyan print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 20, 2013 | HP Officejet Pro 8500 Wireless All-In-One...
MX700 printer does not print in black
you have a clogged jet and ink has dried inside i reckon... the only other thing it could be is the message from the logic board (its motherboard) inside printer isnt getting to the print head or print head itself has malfunctioned - i would suggest to fix but it would probably be cheaper to buy a new one but dont give up.... sometimes they do work if you print pages even tho there is no flow and the heat may dislodge blockage if there is one... But heres a video that may help...
May 06, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Problems with my black ink
The lack print head may have blocked ink nozzels.
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2012 | HP PhotoSmart Office Equipment & Supplies
HP Photosmart 3110 All-in-one not printing black ink but colour
have you found a solution to your black ink problem??? I am experiencing exactly what you describe, no error messages, I have reset the printer, alinged, cleaned etc but still not a single drop of black ink but all the colours are working fine. if you know what was wrong please let me know.
Jan 20, 2010 | HP Photosmart 3310 Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Print quality is terrible
Your printhead is in need of a cleaning cycle...
The black part of the K/Y printhead is pigmented and they tend to clog much quicker than the other dyebase colours. As a result you should run a cleaning cycle from the control panel
  • Setup button
  • Tools option (6)
  • Clean Printhead (option 3)
That will then run a printhead cleaning routine which hopefully will resolve the issue.
Unfortunately as I said the K/Y printheads are poorly built and you may need to replace it if, after 3 cleaning routines the output doesn't improve.
One solution is to switch to a Non-HP black cartridge that uses dyebase ink instead of HP's pigment but that's only if you get this more than once.
Hope that helps.
Feb 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer is not printing and black cartridge has ink Black not printing, changed two cartridges but still no print. Contacted HP who will offer no help unless I use their extortionate phone support system....
Are there any error messages that display on the control panel of the printer or on your computer? That might narrow down the problem and the solution.
With what you have said so far, it could be a couple of things. The printer series you have tends to not print at all unless all of the print cartridges have ink in them. If even one of them is empty or near empty, printing seems to stop, even if you aren't going to print using the color that is empty. My first recommendation is for you to check all of the cartridges to make sure they all have ink in them. Replace any that might be empty.
This sort of issue can also be caused if the electrical contacts between an ink cartridge and the print carriage are dirty. Assuming all the cartridges have ink in them, you should check the electrical contacts on *both* the cartridges and the print carriage. has a web page that shows you how:
Cleaning Electrical Contacts
Go to Step Two in this document for the proper instructions.
If my suggestions don't solve the problem, please post back any other information that might help narrow this issue down. As I previously said, if an error message appears on the printer or computer, please post the exact text of the message. That will help a lot. Thanks.
Oct 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 6310 Cartridge Error: Replace Cartridge
well..did the printer cartridges come from HP?
May 23, 2008 | Office Equipment & Supplies
HP Photosmart C3150 Printer Logo
1,340 people viewed this question
Ben Johnson
