Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
The soap dispenser door on my GE Adora dishwasher (which is less than a year old) has suddenly stopped opening during the wash cycle. It opens fine when I push the button with my finger, but it's always closed at the end of the wash! What do I do?
Any help is greatly appreciated!!
I have exactly the same problem with a Bosch dishwasher, model SHY660C05UC/12/14. The soap dispenser appears to work perfectly, until I put soap in it and try to run the dishwasher. I've tried both powdered dishwasher soap and the tablets.
Any help would be greatly appreciated.
  • 3 more comments
  • Anonymous Mar 15, 2014
    This needs replacing as it's broken, but where to buy part??? Any information greatly appreciated
    bosch
  • Anonymous Mar 16, 2014
    soap dispenser does not always open. have done the cancel method and that works for a bit. it is 11 years old and works great other than this issue
  • Anonymous Mar 20, 2014
    goes to rinse, does not wash and the soap dispenser does not open
  • Anonymous Mar 25, 2014
    the powder dispenser doesn't open during the wash cycle
    President:
  • 1,314 Answers
Both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
1,555 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
