To delete all your inbox messages at once, go to the inbox, select the options, then scroll till you see mark, then a checkbox will show up on all the message in the inbox, then you check all, once you are through checkin, you press option and select delete all checked.
All the messages in the inbox will be deleted. Try it out and see.
On many mobile phones, you only have two options for deleting text messages: deleting one message at a time, or deleting a whole folder at a time. However, the Samsung Intensity (among other phones) gives you the option to delete multiple text messages at once without deleting an entire folder. You just have to know how to do it.
Go into the Messaging menu, either by pressing the upper left option button or by going into the main menu and selecting Messaging (option #2). Select your inbox, then press the upper right option button (Options). Select #9, Msgs View by Contact. The text messages in your inbox are now grouped according to who sent them.
From this view, you can delete multiple text messages at once. Press the upper right option button again and select choice #2, Erase Multiple. Now as your messages are displayed, there is an empty box next to each one. Scroll down through the list and select the messages you want to delete by pressing the center of the directional pad. A check will appear next to that message. To uncheck a message, repeat the same process.
The only messages you won't be able to delete are messages that you've previously marked as locked. If you want to delete a locked message, you'll have to unlock it first, then delete it.
Once you've put a check next to all of the messages that you want to delete, click the upper left option button (Done) and you'll see a confirmation message. Choose whether you want to delete all of the checked messages or only the unread ones, and then click the directional button (OK). The messages you selected will be deleted.
To resume having your messages displayed in chronological order, click the upper right option button and choose option #4, Msgs View by Time.
for you to delete all messages without doing it one by one, go to your inbox, click inbox,
there is a small box next to the word "from", you just need to tick it and click delete. it will delete all messages on that page. once messages are deleted, in will give you the next page, just do the same.
and for you to keep off from spam, click on option at the top (beside sign out), select mail option, then click spam. make sure that "control spamguard" is ticked, then select "empty spam folder" to immediately.
In your messages menu, you would see a sub menu which is to delete messages. This can be achieved by selecting messages > delete messages. When you select it, you would see other options such as options to delete Inbox, sent items, drafts, screened messages and all messages. You have to select 'delete all messages'. If there is no option to delete all messages, then first select your inbox, you would see the option to delete all inbox messages, select it, hence deleting all your messages inbox at once. Do the same for sent items, drafts and any other messages.
follow the simple steps to delete all messages at once from your inbox
step 1
Go to messages
step 2
Select the settings / delete messages option
step 3
it will ask the the folder to delete
step 4
select the folder and press the delete option , it will clear out the messages at once from inbox .
go in inbox,then open options(down left button) then press mark/unmark
then mark all messages you want to delete or if you want to delete all
mark above first message ( square next where its written inbox) then
press delete.
have you gone into your system settings and changed you option from delete on delivery
if you can change any option that is anywhere close give that a try..
This is what you are going to do, go to your inbox and before you Open the inbox messages click on the "Options" do you have the delete property on the display? If you you can now go ahead and delete per message. If this fails to work then you can go ahead and open the messages in the inbox. When you open one of the messages click on the Options to see if you have the delete property. If you do you can as well proceed to delete.
Do this and i bet you your problem would be solved.
Go to Menu--message--inbox--open up the message which u want to delete n then press the option button---u will see Erase/Delete as an option then click OK.Again press OK if asks for confirmation.That's how u empty your inbox.
If u want to delete all the inbox messages then for that also you have an option in the inbox.
Just don't forget to press the "Option" button if u have to see the function.
Ok, here is what you do to delete your messages in the inbox:
1. First you press your messages button where they are located 2. Now scroll down to where it says Inbox and make sure it is highlighted 3. Next press the button that looks like two pieces of papers one on top of the other...it is next to the OK button in the middle but on the left side. 4. Next you will see something that says Setup...press OK 5. Scroll down to where it says Cleanup press OK and you will see Inbox and Sent Items on there. Choose your Inbox ( you can also do the same for sent items) 6. Now just choose how often or how many messages you want cleaned up...then press the OK button. 7. It will automatically ask you if you want to do this now...choose yes
