Question about Bosch HBN 442 / HBN446 Electric Single Oven
BOSCH PIE645EEU Induction hob
This hob comes with a 6 core cable, 2 earth wires, a brown, blue, white and black conductor. It is a 230v appliance. Which conductors should be connected to a phase and which to neutral?
  • Gary Davd
    Gary Davd May 11, 2010
    yu have this listed under a oven ?? what is your model number ?? of the hob??
  • Gary Davd
    are you in the USA??? check the brown close does it have a green tracer on it?? White is Neutral
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Nov 06, 2012 | Ovens
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
Aeg competence e-4100-m, pnc940316609, s-n 31280933 Problem: I have just succesfully changed torpedo shaped component cable tied in to the wiring loom. It had 2 white and 2 blue wires coming. BUT... I...
If there are no other connection ports, and you only disconnected the three, it is possible that (if this is an aftermarket wiring harness) the third was put in for similar units with an additional option of some sort, and is not needed for your model. However, I highly suggest referring back to the place of purchase, as well as the manufacturer to find out for sure before plugging the unit in and using it.
Please let me know if you need further assistance,
Guru, Premium Expert, Phone Support (Chat) @
Jun 19, 2011 | AEG B2100-4 Electric Single Oven
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
With a new Ceramic Glass Induction Hob EHD68210P which coloured wire is the neutral? Brown, Black, Blue or Green.
Standard wiring colour:
Active - Red or Brown
Neutral - Blue or Black
Earth - Green/Yellow.
Best thing is to call an electrician as you do not want to damage your appliance.
Nov 04, 2010 | Electrolux Ovens
What cable size do i need to connect to the hob
Normally, they use a #8 conductor for the range. It's 40 amp circuit.
Nov 06, 2009 | Ovens
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
Bosch HBN 442 / HBN446 Electric Single Oven Logo
303 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
