Question about Dayton 511 Utility Heater
Dayton 150,000 btu that won't stay lit
It is getting fuel, I cleaned the air filter, it sprays fuel and you can see the spark but won't lite
I am having the exact same problem with my Dayton 150,000 BTU. There is fuel, spark and the fan runs but it will not light up. I took the cover off and it would light... but I think that is because the fan was not forcing as much air across the spark and fuel. Seems like the fan is not allowing it to start.... Suggestions?
  • ekim1313 Dec 22, 2008
    my 150,000btu dayton does the same thing, after changing the switch,spark plug, photo cell, filters, i realized it would only light with the cover off... the probelm is the air adjustment on the pump but i have no idea what to set them at....
  • Dayton Master
  • 3,328 Answers
See if there is a pressues switch on the heater one of the tubes could be blocked,
Posted on Dec 08, 2008
Weedwacker won't stay running
replace the fuel lines and check that the filter in the fuel tank( its on the end of the intake fuel hose) is clean. If there is an air leak somewhere in the old lines it will cause the trimmer not to get enough gas.Then clean the carburetor with carb cleaner- take the carb off by removing the air filter first then undo the two nuts holding on the carb and take off accelerator cable remembering which hole it came from. spray the hole carb with the cleaner on the inside and outside then soak it in the cleaner trying to get any dirt out. put it back together and it should start...if not you might need a new diaphragm in the carb.
Jun 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Heater starts and runs but will not go to full force
You can replace the filters ---fuel--- air--- spark plug and vanes in the pump assembly.This is called a fall check up!
Dec 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Dec 08, 2008 | Dayton E50 Heater
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Dayton 511 Utility Heater Logo
563 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
