Question about Hotpoint First Edition WMA12 Front Load Washer
Faulty Hotpoint WMA76 washing machine
My washing machine will not spin. I have tried the manuals suggestion by removing the washing to see if the fail safe switch resets. Any ideas? my washing machine wont spin at all it fills then starts to drain im wondering if this anything to do with my electric going while my washing machine was in mid cycle it span that day just asnt worked ever since also my washing machine is a wma10
  • Gary Davd
    Gary Davd May 11, 2010
    This is a UK model not a USA I dont know of anybody here that has info on UK units
It may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Posted on Feb 16, 2008
Wma76 spin and door lock issues
Most likely a motor control issue or possibly the motor itself
Oct 30, 2017 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
The machine fills up WMA76. It dosnnt appear to wash but empties. Then it displays ON on the display board and will not do anything else. The only thing it will do is if I forward it manually to the...
Apologies - I don't have a solution but I do have exactly the same issue and wondered if you'd found the cause since it's been three months since you posted?
TIA.
May 26, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
Extremely noisy on spin cycle
I would agree with your initial diagnosis that it is the main drum bearings that is the source of the noise.,
try and spin the drum by hand, if it feels rough, or grinding then it is the bearings, also try lifting the drum up and down, if you can feel movement, again it confirms bearing failure..
If you are not sure, remove the belt and try it again, this is done from the rear, remove the lower panel and slip belt off. this will give you the opportunity to make sure the noise is not from the motor.
If the bearings have gone, it is a major repair, and I would not recommend a DIY repair, as it is a complete strip down.
If the m/c is less than 5 years old, you may be able to get it put right under the Hotpoint 5 year part guarantee, you pay for labour, about £90.00, you would have to check with Hotpoint.
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Oct 13, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machine
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Jun 27, 2007 | Hotpoint WMA76 Front Load Washer
Hotpoint First Edition WMA12 Front Load Washer Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
