Question about Microsoft Xbox 360 Console
No sound I have a couple of games where the xbox displays a message saying u must set the console to PAL 60 but when i do it displays the picture but no sound
  • 40 Answers
If you are still under warranty contact microsoft. That is the best solution. If not bring it to a video game store that will take a look at your console
Posted on Feb 16, 2008
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
My xbox is black and white i changed the pal 60 to pal 50 and my game isn't supported
Hi a lot of games on xbox need pal 60 to run properly, bought my lad a xbox and then had to buy him a new tv as well because old tv was only pal 50 and most of the games he wanted to play wouldn't work with it, the tv carnt keep up with the xbox graphics!
Sep 25, 2010 | Microsoft Xbox 360 Console
Chicken wafflez
change your pal setting from 50 to pal 60 go to my xbox , then system setting , thencounsel setting, then pal display setting select pal60 , confirm let me know bluchevy20042000@yahoo.com
Apr 04, 2010 | Microsoft Xbox 360 Console
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
PAL 60 Display Problem
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/917304
Please let me know if you have any issues.
Regards,
Feb 12, 2010 | Microsoft Xbox 360 Console
NO PICTURE
first check to see if the game is running at 50 or 60 pal make sure its the same on your xbox or try turning off your console take out the game turn it back on with the guide button the hold right trigger and y this will reset the display settings on your console
Jul 17, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Pal settings
change to pal 60 automatically with the setting in the dashboard if this isd not it it may be your tv is not compataible
Oct 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
