Question about Whirlpool Calypso GVW9959K Top Load Washer
LD.;.................... washermachine What does LD mean on the washer?
  • perri Feb 16, 2008
    i dont know. sry
  • 770 Answers
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Posted on Feb 16, 2008
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Message LD on washer
L D code meanning long drain. lint causing the problem . and restricting the pump inlet .. remove pump and clean out .. ****
Dec 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LD mean?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
Oct 13, 2009 | Kenmore Elite 45986 Front Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer beeps Ld a few minutes into each wash
LD means = Long Drain
Problaby samething inside the pump
Is your machine calypso
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
175 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
