Question about Sirius Stiletto 2 Satellite Radio Receiver
Recording Hello! Just got the new stiletto2 from sirius.. can't record live satellite??? what's going on?
  • Anonymous May 10, 2008
    after recording the stiletto 2 states file empty
  • walsh70 Nov 03, 2008
    I am not able to acquire radio replays from my stiletto 2. My satellite has good stength to acquire songs.
Check your settings, click on the "heart button" You should be good to go. I LOVE my stiletto 2. I've had it for a few months. Good luck.
Posted on May 04, 2008
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
How do you save music to the sd card
The microSD card for the Stiletto2 can only hold your MP3s.
All Sirius content is recorded to the internal memory of the Stiletto2.
Hope this helps.
May 03, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
Jan 05, 2010 | Sirius Stiletto 2 Portable Satellite Radio...
How do I transfer stilletto 2 files to PC
Run the audio out from the stilletto headphone jack or dock to you PC's microphone port and record into sound recorder. Only current way to bypass its DRM.
Jan 03, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
My receiver comes on and I get the error message "Acquiring Signal" and everything appears to be connected. Just started doing this. Using the Aux. jack in my Nissan.
First...you still need a sirius antenna plugged into the device. If you just started using this you may just need to resend the signal. Just call the sirius/xm people and follow the recorded prompts to send a new satellite signal. Then make sure you are parked somewhere that it is receiving a good signal and wait. It could take up to 30 minutes to reset completely.
Oct 24, 2009 | Sirius Satellite Radio Receiver
Backseat-tv not work
Go to the Chrysler owners website and download the owner's manuals, it is all there.
May 04, 2017 | Sirius Satellite Radio and Backseat TV...
Stiletto 2 deletes recordings
I'm a relatively new subscriber, only having my stiletto2 for 3 months. It just started "not recording" and "deleting my recordings". In researching, I came to this thread. Since no one really seems to have posted a real solution here, I'll share what I've found elsewhere.
1.) Check to make sure your SL2 has the latest software (ZAP). To find out what version you have, navigate to Settings >> Device >> Device Info. If your software is not up-to-date simply connect your radio to Internet Radio for about an hour and it will be downloaded. You will get a notice on your screen when the update is complete.
2.) Perform a Full Shutdown of your SL2 at least once a month by holding the power button down for 10 seconds. If you do a lot of recordings it's advised to perform a shutdown weekly or more for best results. This will flush the system, clean up and remove old and expired recordings/replays and reduce general screen lag. For some this simple step has eliminated missing recordings all together.
3.) Do not use your SL2 as an archive device and try to avoid using your internal memory over 50% for the time being. If you do a lot of recordings it's also advised to disable Radio Replays.
If 1-2-3 don't work, try 4
4) Set and Erase
4a. go into your Settings Menu>>Device>>Reset & Erase.
4b. As soon as you complete the process (Reset & Erase) and have rebooted, you will need to connect to Wi-Fi again to again download the baseband update. Let it run for at least 30 minutes to ensure that it is able to get the entire update. Then tune to Satellite Radio it SHOULD complete the baseband update.
4c. You should see the Updating SIRIUS message for about 7 minutes. If it's only up for a minute or two, then it may bet hat the update failed again. You can check the Service Info screen to be sure.
4d. If you then shutdown your SL2 (by holding down the power switch for 5 seconds) then turn it back on, it should complete the baseband update process.
Apr 09, 2008 | Sirius STILETTO 100 MP3 Player
Sirius Stilleto 100 skipping issue
Usually this is a signal issue and it happens when recording indoors mostly, right? The signal dropps but only for a second or two so when you look at it its fine. you've probably notived it cutting in and out when "live" from time to time. Use your signal meter built in to the device and find the strongest signal location. If that doesnt work or its not the problem, update the software. If that doesnt work try running the recovery software but only as a last resort because you'll lose your recordings.
SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Feb 20, 2008 | Sirius STILETTO 100 MP3 Player
Sirius Stiletto 2 Satellite Radio Receiver Logo
355 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
