Question about Eclipse (AVN7000) Car DVD Player
Connection problems i have connected a panasonic cqvd7001u radio and it is not showing any picture when connected why is this happenung?
  • 4 Answers
The picture will only show when a movie is playing. it will not show you what is on the main screen like Navi or FM or whatever. Sucks.. This is through the RCA Video Out..
Posted on Feb 27, 2008
My Panasonic PT-56DLX25 television show a very faint picture. The lamp was replaced only a few weeks before and showed perfectly until now. How can This problem be resolved.
If it did have a picture then try and remove the new lamp and reseat it, sometimes they don't make good connection the first time, then make sure the lamp cover is back in place correctly. If still not working observe the front panel indicator lights as they should blink in a particular pattern such as power indicator flashes.
Oct 11, 2013 | Panasonic PT-56DLX25 56" HDTV
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
I need a program that will allow me to download my pictures on my computer . i have lost my cd that came with it
Contact Panasonic for the software. An alternate solution is to obtain an SD memory card reader to USB
connection. Lexar used to make them, and you might try Targus. The card reader should show up on your computer as just another input and the SD card should show up as files with pictures in jpeg format.
Nov 16, 2009 | Panasonic Lumix DMC-LS80 Digital Camera
PANASONIIC CQVD7001U
it should be 0000
if it's not then it has been changed in the past. you can reset it, press and hold the joystick to the right for 10 seconds and then press the power button on the remote, then put in 0000 when the screen asks for the security code and it should be like new. just to let you know you must have the remote, it is a definite need.
Jan 29, 2009 | Panasonic CQ-VD7001U Car DVD Player
SC-HT730 Color problems
What kind of connection are you using? If you are using a component connection or a RGB connection this could be causing your problem check the leads and if so replace new leads.
Apr 06, 2008 | Panasonic SC-HT730 System
Radio works cd/dvd does not.
What do you have your remote wire for your amplifier connected to?
Dec 05, 2007 | Panasonic CQ-VD7001U Car DVD Player
Eclipse (AVN7000) Car DVD Player Logo
52 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
