Question about Dryers
Condensing tumble dryer not running
When power is applied and dryer turned on, sounds as though motor is running but drum is not turning. If left on smell of burning developes. Have removed small panel at rear of dryer and I believe the drive belt for the drum is intact. Wondered if you could shed some light.
Model Hotpoint Aquarious Condensing Tumble Dryer CTD00.
  • 1 more comment
  • Anonymous Mar 15, 2014
    Tumble dryer turns on ok but when you press start the consumer unit in house trips out and there was a smell of burning from machine.took off side panel and the motor has burn marks on top and cables going in have started to melt hence the burning smell
  • Anonymous Mar 20, 2014
    The power turns on, but when I hit start the drum will not turn.
  • Anonymous Mar 23, 2014
    Water is leaking at the bottom of the front of the tumble dryer.
    Sergeant:
  • 236 Answers
Has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Burning smell
Sounds like the motor has gone. If this is the case, its time for a new one.
Dec 27, 2013 | Indesit IS70C Electric Dryer
I sensed a bad burning smell from dryer motor. The dryer drum belt is still looking good and tight. The 4 drum rollers supporting the drum are looking good and no friction. The dryer shut itself...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Whirlpool LGB6300 Gas Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer drum won't turn, though dryer sounds as if it is
Don't run it like this any longer- I'm 99% sure you have a broken drum belt.
Unplug the dryer, take the inspection plate off the back, and see if the skinny little belt is held around the motor pulley apparatus.
The reason you shouldn't run it any more before determining status of the belt, is that the element(s) will burn out when the belt isn't in place.
Dec 15, 2009 | Dryers
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
Maytag dryer, LDG9334, won't start to rotate, burning smell
Hello Friend, From my experience, it sounds like the motor is tired and getting ready to fail. Only option is to replace. Happy to help, Tim.
Jul 11, 2009 | Dryers
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
635 people viewed this question
Top Dryers Experts
Marvin
Marvin
