Question about Intel Celeron D 355, 3.33 GHz Celeron D (BX80547RE3330CN) Boxed Processor
Cpu overheat well its very simple...my cpu goes too high in his temperature and the cooler fan goes crazy and its making a huge noise.it starts with 3000 rpm and it can goes 5000.and the cpu goes at 60?c only with windows running... in about 30minutes.no games,programs or anything else.Yeah, i already have clean it and put new termal pasta. So i dont have any idea of what its going on with the cpu. Could you help me?thanks...
Todays CPU fans are set to automatically up their RPMs if the processor overheats or is overtaxed. But the trick is when the fan itself is not cooling enough but rotates and makes this sound like a heicopter. Since you see it turning, you may not realise its cooling is poor. The best and long last solution is get a brand new fan and install it. The baby will stop crying.
Good luck.
Posted on Feb 18, 2008
My dell mini inspiron is making a loud noise and then windows display but always flashing
The loud noise indicates high processing from CPU and/or GPU, increasing the temperatures, therefore the need from cooler to operate at max. However since your screen is flashing, it means something is wrong with your GPU. You probably got those mining malware, I recommend to start in SAFE mode (F8 at start) and then run a reliable anti-malware, anti-virus too, start to uninstall programs, etc. If this is too complicated to you, it might be better to just re-format and re-install the entire Windows thing. Never trust in pir8 software, a LOT them contains mining malware today.
May 31, 2014 | Dell Inspiron 1501 Notebook
Honeywell tower fan
call the HVAC man. LOL
it's not a cooler or A/C, that the sales hype states !
its JUST A FAN, and fans only circulates air.
or if you are inshorts only, it help with wind chill and sweat evaporation,
I have a huge fan in my garage. just for that, and fume , reduction.
you set 68F and the temp goes UP, ?
but what goes up , do you mean the actually measured temperature? state what told you it went UP?
if yes, (actual temp) sure it can, if there is hotter air , say up high?
then you mixed in hot air with cooler air down low, and guess what
it does get hotter. (physics 101?)
what do you want to go down. ?
the actual air temperature?
or do you think you bought a real air conditioner.
to make real tempeture go down
buy a real air-conditioner, not a fan.
Sep 28, 2013 | Honeywell Hwlhy108 Quietset 8-speed Whole...
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
Loud fan noise every 3-4 minutes
It's probably the automatic control of the CPU fan.When the temperature goes up the fan speed increases witch generates more noise.When the CPU cooler accumulates dust the temperature rises faster so try and see if that's the problem. If that's not it you can download a software to manually control your fans.I recommend SpeedFan and you can get it here: http://www.almico.com/sfdownload.php
Dec 17, 2011 | Compaq Presario CQ5110F (NP185AA ABA) PC...
My laptop makes a high pitched noise
The high pitched noise you hear is most likely caused by the CPU cooling fan on your laptop. If you suspect that this high pitched sound is caused by the fan going out, you can spray your laptop with compressed air to get the dust off of the fan.
This solution will make your laptop work at a cooler temperature, and reduce the noise.
If the problem persists, seek a certified laptop repair specialist.
May 22, 2011 | Computers & Internet
My cooler for my laptop wont work. it over heats and makes my laptop over heat also.
make sure the cooler fan is getting power test the leads that attach to the cooler make sure the connection is good and not faulty
also you should clean the cpu make sure there is no dust built up on the fins of the cpu
(dust will cause static) to computer overheat and lots of unforseen problems
also you purchase a portable usb laptop cooler pad
hope this helps
Mar 06, 2011 | Rocketfish Universal CPU Cooler RFUCPUCF...
Msi vr610 fan very noisy.how do i cure, get new part
Its a typical failure of MSI fans from those times. Unfortunately the exchange part will not solve your problem. (I read it in comments lots of times.) I own a VR610 and fixed the problem with grease. I disassembled the fan and took out the paddle wheel. I cleaned the pin and the hole both and filled the hole with grease. I used small portion of (lithium based) grease like on bicycle. The fan is noiseless since 1,5 years. :)
Sep 29, 2009 | MSI VR601 Notebook
I think my processor has burned out
A CPU that overheats will shutdown (ie thermal overload) and usually it will start up again after it has cooled down. If this problem is not corrected eventually the CPU will fail.
A replace CPU may fix the laptop provided no other damage was done to the motherboard.
Sep 16, 2009 | Computers & Internet
Nx9010 fan noise
What your after is a software fan controller, it might be possible to find one but your fans spin for good reason. The cpu runs very hot in those laptops and needs sufficent cooling when its busy otherwise it will overheat. Something that might bring the need for the cooler down to a minimum is a Laptop cooler fan that has two large lo speed fans underneath your laptop to keep it cool. I found this:http://www.it247.com/Product/255-761345-75004-2/?channeltype=InternalPCCables&level1cat=Computers&keywords=255-761345-75004-2&prodid=255-761345-75004-2&level2cat=BareBonesPCs&campaign=froogle|internalpccables|-&utm_medium=InternalPCCables
sorry about the huge link. I would do some shopping around for an item like this.
Hope it helps
Nov 11, 2008 | HP Compaq Business Notebook NX9010
Mesh Matrix 64 start up problem
First there is an on off switch on the back of your power supply. Switch that off. Take out the memory chips, then re-insert them. Turn power switch back on. With the case still open. Power it up. If it comes on. Look to see if the cpu fan is still running. If it is not turning replace the fan. If it runs you may have other problems, possibly a power supply, CPU overheating, and or switch problems. Now in other cases high end video adapters tend to overheat and causes system freeze ups and causes possible shut downs. I would still have it checked out professionally if the problem persists. Hope this helps
Sep 16, 2007 | Computers & Internet
Intel Celeron D 355, 3.33 GHz Celeron D (BX80547RE3330CN) Boxed Processor Logo
146 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
