Question about Toshiba Satellite A100-S8111TD Notebook
Video having trouble getting video on screen(samsung plasma)........getting audio.......unit is a t-352..any help with this matter would be appreciated
Damn u
Posted on Feb 19, 2008
My Samsung Plasma TV has vertical lines on it. Is there a way to test the unit myself without resorting to taking it in to a repair shop??Any ideas would be greatly appreciated!!
means the glue or rubber padding on the gold static conductors are coming unstuck at the top of the screen just under the top of the plastic frame or has dirt...maybe this video is helpful, also happens to all Plasma and LCD and computer Monitors, it's definitely not a Motherboard issue it is a simple annoying fix but a real pain to get too if you have the patience.
LCD TV Repair Secrets Vertical Lines on the Screen
Apr 26, 2017 | Samsung Televison & Video
Samsung Plasma LN-T4671F has 5" horizontal lines across the screen that gives a double and blurred vision on the pictures. Thanks I will appreciate any help you could provide on this.
If you wish to get some details; visit the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 29, 2017 | Samsung Televison & Video
How do I fix a Samsung tv model htp5054x/xaa? I have power and I can hear audio but no image.
First trouble shooting steps is to try a different source, or at least a different cable. A bad HDMI cable can allow sound but not image. Also look closely at the screen. If you can see a dark image, it would indicate that the lighting system has failed. Check this video for some tips. Samsung Plasma TV Repair How to Repair and Replace Main Board
Sep 07, 2015 | Samsung Televison & Video
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details.
Apr 07, 2017 | Maxent MX-42XM11 Television
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
No Video
you need to start the system without a disc then go into setup and reprogram the system for audio setup
Feb 26, 2008 | Amphion Mediaworks T342 System
No video from dvd/receiver; getting audio; receiver is a amphion MediaWorks T-352; tv is a samsung 42" plasma; any help would be appreciated
What type of lead are you connecting it with?, a Scart maybe if so that could be your trouble, make sure no pins are bent, both ends of the lead, reconnect it and test if still a problem try another lead. Common fault with Scart.
Feb 18, 2008 | Televison & Video
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Toshiba Satellite A100-S8111TD Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
