Question about GE DVL223GB Gas Dryer
Won't Dry Clothes
The dryer turns and air is flowing although there is no heat being produced. I checked to see if there were any breaks in the heating element and it is in good shape. I suspect maybe a faulty thermostat but I'm not experienced enough to diagnose this problem myself. Spins, but zero heat. There are two "timers", the one that actually is set for certain time limits works, however the other doesnt "tick-down" at all and if left alone, will run for hours. Both these problems occurred at the same time. Additionally, for some time now the dryer has taken on a hunger for my clothes...leaving nice rust-colored marks, holes etc. Not sure if two are related. I've no clue about ohm's, thermostats or any other technical stuff. Just wondering if it'd be wiser to just purchase a new dryer as opposed to trying to arrange someone to come look at it. Any advice welcome :)
  • HulaHB Feb 16, 2008
    The first paragraph was not written by me. I have no clue what "stats" are or "t/d" is. As for changing them, well I wouldnt know what there were, what they looked like, nor how to change them. Sorry, all female here. While I figured how to replace a blower motor in my Blazer, fixing dryer's is a little beyond me. ;)
    Is it worth calling a repairman out or easier and more cost effective to just replace the dryer entirely? It's only 8yrs old and I didnt bother with the insurance.
  • stevemostell Sep 28, 2008
    Same issue, the machine tumbles but no heat. The sensor mode stopped working last week, now no heat.
    Sergeant:
  • 236 Answers
The stats go a lot on t/d. change them all just in case.
Posted on Feb 16, 2008
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | Kenmore Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer takes 2 hours to dry clothes/towels. Also there is no lint on the lint screen.
With dryers taking too long to dry this usually means you have a clogged vent or lack of air flow which is suffocating the dryer causing it to not heat to its full potential. Turn your dryer on and find out where it vents out to and see if the flow of air is strong. You may have a crimped dryer vent, or the exhaust flap where the air comes out could be stuck. Worst case scenario is your heating element has a wire burned in two causing it to partially heat but not enough to dry. You'll have to visually check for that by exposing the element and looking for a break in the wiring, but this is not a common thing. Check your air flow issue before you go looking for the problems with the element.
Nov 08, 2010 | Kenmore 64602 Electric Dryer
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Won't Dry Clothes
If you have a ohm meter... ohm out the themostates they should all be closed letting power though... you could .. IF Real Careful take the wires off themostate hook them together bypassing themostate to check... make sure wires are taped or in a position where they will not touch any thing or it will short out...make sure you dont touch wires while plugged in
Aug 30, 2007 | GE Profile Harmony DPGT750EC Electric...
GE DVL223GB Gas Dryer Logo
117 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
