Question about Canon BJC S450 InkJet Printer
Printing black text
Black text prints some lines lighter than others--tried maintenance and many adjustments but problem still exists---printer is 6 years old--are parts worn out --help please
    Scholar:
  • 49 Answers
You can try this to really clean the print head: Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Aug 20, 2008
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Canon Multipass F80 printing is very faded.
Not a new printer, but a new printhead will solve your problem. The number is QY6-0041-000. The cost is around $40.00. Instructions come with it to help you change it...
Jun 29, 2009 | Canon MultiPASS F80 All-In-One InkJet...
C4200 Not printing black ink, which is new
Its purely your CATRIDGE problem...so please open up your printer and check for the two small black colored boxes..in that you can easily identify the B/W one....so if its lighter in weight compared to that of coloured one....you need to refill it or buy a new catridge......THIS is the only solution to this problem..
Jun 22, 2009 | HP Photosmart C4180 All-In-One InkJet...
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Copies Poorly (black)
sounds like a resolution issue in the scanner settings.
http://tinyurl.com/6qcpgy
May 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
Canon BJC S450 InkJet Printer Logo
135 people viewed this question
old marine
old marine
