Question about Garmin StreetPilot C330 GPS Receiver
I can not turn off my unit
Please i need help , i can not turn off my unit, the power button doesnt response neither the buttons on the touch screen.
please help me
neto2708@msn.com
  • tito2708 Feb 17, 2008
    thank you very much ! very helpful.
Just had same problem. use fingernail under the Garmin insignia on front (it's silver) and pull out a little. There's a reset button on the right.
Posted on Feb 17, 2008
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    Touch screen doesnt work only used three times
    1.hold down the hint button while turning the unit on.
    2.when leapster menu screen appears, press the A button.
    3. touch each of the crosshairs that appear with the stylus
    4. you restart unit.
    Jan 26, 2011 | LeapFrog Leapster 2 Learning System
    Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
    Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
    Nov 24, 2010 | Husqvarna Designer I
    Can not get past I agree, no response when touching screen.
    did u try reseting the unit?
    if yes but still same then pls try to calibarate ur screen.
    turn off ur device,
    while off, hold the upper-left corner of the screen while turning the power on
    leave the power button when its on but continue holding(30 secs) the upper-left corner of the screen untill "Press dot" appears.
    thanks
    Jul 29, 2010 | Garmin nuvi 255W GPS Receiver
    Touch screen and push buttons are not responseive.
    Make sure the switch on the side that locks the buttons is not switched on. To be safe, switch it on (so that the red shows) then off.
    Oct 11, 2009 | Dell Axim X51v Pocket PC
    Touch screen doesn't work. It is a kenwood KVT512 DVD/CD player with a 7" touch screen. at first, I couldnt get any of the buttons to work, not even the power button to turn the unit off, so i pushed the...
    The password can be entered by setting the arrow buttons, if u know the password, or get kenwood to give their default password and check that the touch screen is not getting grounded, 'cos that's when it goes apparently, dead...sodeep
    Jun 23, 2009 | Kenwood KVT-512 Car DVD Player
    Touch screen does not work
    1) Ensure that a cartridge is not inserted
    2) Hold down the Hint button while turning the unit on
    3) When the LEAPSTER menu screen appears, press the A button
    4) Touch each of the crosshairs that appear with the stylus
    5) Restart unit
    Mar 22, 2009 | Leapster Learning System
    The touch screen on my sons leapster doesnt work.
    Buy another one from the same store and just swap them.
    Feb 20, 2009 | LeapFrog LeapSter L-Max Console
    Leapfrog Leapster
    I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
    1. Unit must be OFF and NO cartridge
    2. Hold down the HINT (?) button while turning the unit on
    3. When Leapster menu screen appears, press the A button
    4. Touch each of the cross hairs that appear with the stylus
    5. Restart unit
    Dec 01, 2008 | LeapFrog LeapSter L-Max Console
    Garmin StreetPilot C330 GPS Receiver Logo
    35 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
