Problem for Printers
Generic problem for all Printers
Tattoo gun set up
i have no instructions with a tattoo gun that i have just bought to set it up from scratch i have searched the web but still cant find anything that will help me
Same Problem
Apr 20, 2009
-   i just a bought a tattoo gun without any instructions
can you help?-
apalenapa Mar 19, 2009
-   got a tattoo kit with no instructions, need to know how to set up all this parts.
-   Guest Mar 13, 2009
-   i need detailed instructions for the "1 gun series tattoo kit machine - copper g".-
mikerefino Jan 11, 2009
-   Just got a new set and do not know how to set it up and have no instructions
-   Guest Dec 02, 2008
-   i've been trying to set up my tattoo gun but i dont know how to hook up the rubber bands. PLEASE HELP ME!!!!!!!!!
tdonohue90@yahoo.com-
tdonohue90
Best Solution
posted on Jan 08, 2009
Rank: Apprentice
Rating: 93%, 17 votes
First off you should of never bought a "kit", you should start with an
apprenticeship with an artist near you. Setting up your machines is a tricky process when you dont know what your doing, Im going to assume that you have no idea what capacitor is on your machine? I will give the basics since I dont know what machine your using, the gap between your a-bat and coil should be the thickness of a dime, and a nickel for shading. Place your needle in the tube and slide in the vise and put on the a-bar. Take about 3 elastic bands and place them around the needle and the the back of the machine, this is done to make sure the needle does not jump around on you. Set your power supply to no more than 6.5 volts, since your not using that many needles you don't need the power. When you tighten the vice around your tube you want to make sure that there is a very very small amount of the actual tip of the needle sticking out. Before you even think of tattoing someone else try doing a few on yourself, and if your not happy with the results at least then someone else wont be wearing your mistake
Was this helpful?12 people thought this was helpful
Solution #2
posted on Oct 05, 2009
Rank: Wiz
Rating: 83%, 9 votes
Basically the only way to learn is to find an artist nice enough to show you the ropes. Other options... the grueling process of apprenticeship. Seems most tattoo shops act as if its some exclusive secret and you have to be special to do tattoos. Grab a tattoo machine, learn how to be sanitary on a medical level, learn the basics of your tattoo machine, buy a slab of fresh pig hide and go to town!! dont let the tattoo artists bring you down by instantly rejecting your thoughts of tattooing whether it be at home for personal use or prospects of working at a shop. Its not that special and its not exclusive, you do not need to be an "artist" just have a steady hand and know how to follow a line, like back in kindergarten :)
good day people
Was this helpful?1 person thought this was helpful
Solution #3
posted on Nov 05, 2008
Rank: Apprentice
Rating: 88%, 4 votes
You may have figured this out already, but I had the same problem. I just got a kit and it came with no instructions whatsoever. So I went to expertvillage.com. There's quite a few videos to help you figure it all out.
Was this helpful?2 people thought this was helpful
Solution #4
posted on Dec 11, 2009
Rank: Apprentice
Rating: 0%, 0 votes
ive got a question, ive been tattooing for 4 yrs, but! ive never fixed my own guns or done maintenance ive always sent them to my good friend who is a gun builder but im in dier need as he is on holiday in africa mobile costs are immense, heres my problem... i brought a percy waters machine which i found where you put the clip cord is so tight it felt un natural so i changed it i think i blew the capacitor but not sure when i put in on and push the pedal my amps and volts jump up to a lot.... can you help lol
Solution #5
posted on Dec 10, 2009
Rank: Apprentice
Rating: 0%, 0 votes
hi i got a tatto kit for personal use and for tattoing equuipmont not people but i am having a problam geting the iarn going i have pluged it all in push on the foot pedle and it is just cliking/pushing the nedle dawn ones not vibrating whats rong can s=any one help
Popular Solutions for Printers
Brother MFC-210C All-In-One InkJet Printer
1 Solution
Polaroid PoGo Digital Photo , Using Zero Ink Technology...
1 Solution
Canon PIXMA MP830 All-In-One InkJet Printer
1 Solution
Questions and Unsolved Problems for Printers
IS Lexmark 810 printer good
What should we be concerned with concerning any glitches associated with the SAMSUNG CLP-315 Colour...
(More)
What should we be concerned with concerning any glitches associated with the SAMSUNG CLP-315 Colour Laser Printer we wish to buy
Thanks!
green light flashes all the time - canon pixma ip5200
My paper won't feed properly. It appears only one side has a wheel to feed the paper. W.hen feeding...
(More)
My paper won't feed properly. It appears only one side has a wheel to feed the paper. W.hen feeding it tends to lean to one side going through crooked and getting jammed. I can't see what the problem is because the top does not come up to see inside Only the glass area to copy comes up.
canon mp140 eror 5100 code 2
20 Other Users Have The Same Problem - Continued
Comment by sketco, posted on Nov 14, 2008
i just bought a tattoo gun kit but there are no instructions and i need to know how to set it up from scratch so know how it all works.
Comment by jonboy69, posted on Oct 13, 2008
bought a tattoo kit but got no instructions on how to set it up does anyone have any info on this please
Comment by albatrossmot, posted on Sep 08, 2008
I have put the gun together but the needle drops down and there are little rubber bands which I am not sure of their job. Has anyone got a diagram they can pass on to me ? Thanks.
Comment by Guest, posted on Sep 01, 2008
just bought a kit n got no instructions on how 2 set it up?
Comment by Guest, posted on Aug 15, 2008
tattoo gun won't buzzzzzz
Comment by Guest, posted on Aug 06, 2008
got tattoo kit online and dont no how to put it to gether
Comment by Arneee, posted on Aug 02, 2008
free instructions on how to set up a wingli hero tattoo gun
Comment by Guest, posted on Jul 10, 2008
i cant put the needle on
Comment by Guest, posted on Jun 22, 2008
ive bought a tat kit and im just woundering how to set it up ive done a couple of tats on my self they look ok , but i just want to know about the tensioner on the back what setting do i need it to be and about the tips and needle what length can you help
Comment by jock21, posted on Jun 11, 2008
got the gun-just no instructions need step by step picture setup if you can
Comment by BigdaddyTDW, posted on May 25, 2008
I have many tattoos and a skill of drawing. I know the basics of
tattooing and bought a kit online with every thing. I want to start
learning but I can't set the gun up. I hook everything up like I'm
supposed to but it is not coming on when I press the pedal. Does anyone
know what could be the problem. The kit is new from a tattoo supply
vendor. I can't practice if I can't get the gun to work correctly. And
for those of you who think I want to tattoo myself or others until, No
- I want to do it the right way but don't have time to live at a local
tattoo
shop. Thanks for any help possible! "Big Daddy"
Comment by Guest, posted on May 25, 2008
I have many tattoos and a skill of drawing. I know the basics of tattooing and bought a kit online with every thing. I want to start learning but I can't set the gun up. I hook everything up like I'm supposed to but it is not coming on when I press the pedal. Does anyone know what could be the problem. The kit is new from a tattoo supply vendor. I can't practice if I can't get the gun to work correctly. And for those of you who think I want to tattoo myself or others until, No - I want to do it the right way but don't have time to live at a local tattoo shop. Thanks for any help possible! "Big Daddy"
Comment by Jerseychic, posted on Apr 19, 2008
Same thing, bought kit, has everything except directions and a lot of funny things i never saw before, Bought on ebay almost $300 and has no brand name on it, only says made in CHINA and a serial number that dont come up on the internet
Comment by jafari6969, posted on Feb 28, 2008
i just baught a tattoo gun and someone told me that it had to be calibrated. but i don't know how to do that.
Comment by whealink, posted on Feb 23, 2008
my gun keeps spittin most ov the ink out whn i start it plz hlp
