Help my anti trac light indicates that trac is off the od lights indicates its off and a door ajar light stays on even though doors are closed i dont have an owners manual so i don't know how to fix
  • 123 Answers
More info PLZ.
Thanks,
x-b-m
Posted on Feb 19, 2008
How do i slove my door ajar problem
Try spraying wd40 into each door latch. Do it one at a time then open and close the door about a dozen times spray some more in there after about 6 open and closes. Do this with each door and even the hatch. This should clear ya right up.
Jan 05, 2011 | 1996 Ford Explorer
Ford Taurus SE 1999. Dome Light - Door Ajar indicator problem. This is an intermittent problem, hence far more difficult to isolate. OK. I will be thorough in describing this "set of problems" as I do...
i must say that i feel your pain with this,, my door ajar light does the same thing but my dome light doesn't come on when the doors are open, i have to flick the switch on the dome light to make it come on. In my opion and i stress my opion it saounds like a issue with the body controller, im not sure what ford calls it but it controls all the body functions, i dont think the low coolant light is connected to the body contoller but i dont know this for sure, i think that light is controlled bny the engine ecm. some times a dealer can connect to the body controller and see if there are any fault codes for circuits that it controls and or monitors, also they can reflash or update the configeration and or calibration level cause ford release's fixes for issues all the time, same theory works for any control module on a vehicle. i dont think any of the auto parts stores have the right program to connect to bofy controlers but i could be wrong, worth looking into. i only put up with mine cause i use it as a beater, if you are worried about your dome light staying on and drianing your battery then you could pull out or disconnect the dome lights for the time being, its not a fix but just a band-aid.
Feb 18, 2010 | 1999 Ford Taurus
My alarm activates and interior light comes on when door is
Replace the drivers door switch, it's shorting out. It's on the B-pillar below your door latch, covered in rubber that you can pull off to get access to it. You can take it out, just tie a string to the electrical connector and tape it to the door so you don't loose it. The switches are fairly cheap at the dealership.
Nov 22, 2009 | 2004 Hyundai Elantra
Door ajar light & washer fluid light & bell dings,
sound like your fluid sensor may be stuck or bad if light stays on try tapping the washer motor on the resevoir if it goes out faulty sensor as for the door ajar light it might have bad connection with sensor saying the door is closed local dealer should be able to troubleshoot sensor
Aug 23, 2009 | 2003 Ford Expedition
Door ajar light stays on
go to your local parts store and buy a can of PB BLASTER lubricant then open each door and spray the latch assembley really good then close and open the door 10 to 15 times. do this with each door. the door ajar light switch is located in the door latch assembley and cannot be seen so soak the latch assembleys really good so lube reaches the switch. these switches sometimes get stuck but this usually frees up the switch
Mar 25, 2009 | 2003 Mercury Mountaineer
"Door Ajar" signal on dash panel stays on even when doors are clo
there should be a switch mounted( or more than one) in the door jamb that tells the car when the car door is open...i will probably look like a little plastic plunger...might be broken off or bad internally
Feb 22, 2009 | 2008 Pontiac G6 Sedan
Sable 1996 dome and inside lights do not go out with doors closed
lol....dont feel bad.....it happens to ALL of us
Feb 21, 2009 | 1996 Mercury Sable
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Dec 19, 2008 | 1996 Ford Taurus
Door ajar indicator stays on
you may just need to adjust your door jams they may not be closing properly, the other thing you can try is opening one door at a time and putting your finger on the switch usually in the lower l/h corner of b piller and see if the light goes off if not this may be the problem and replace the switch
Dec 18, 2008 | 2003 Toyota Corolla
Computers & Internet Logo
David Payne
David Payne
