Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Y Component Cable Related - Internal Static Noise
My Hitachi 42EDT41 42" has recently began giving off an unusual static noise from some internal component within the set. It has not effected picture or sound quality yet. I have trouble shot cables, connections and external components was able to isolate the problem and make the static noise go away when I pull the "Y" video component cable from the AV1 port. When I put the Y cable back in its port the static clicking like sound comes back. This problem exists using any of the avaliable inputs (AV1,AV2 or AV3). I fear there is some resistor or internal connection that needs replacement or cleaning. Any ideas ???
  • 7 more comments
  • Derek Feb 17, 2008
    No. It is not volume related. It appears to be an internal component un related to audio or video quality.
    I have bypassed the cable box all together and run the cable from outside directly through a grounded surge protector and then straight in to the back of the t.v.- problem still exists.
    Everything is well grounded now and the problem still exists. This sound is definetly coming from an internal board.
    What is an "SSB" and what do they cost?
    I am using high quality Gold Monster Cables and have swapped them out several times. Problem still exists :(
    no overlapping external cables
    connections are firm and snug and I am using higher quality cables. set is well grounded through a surge protector equipped with a ground connection.
    I did notice that the noise is more predominant with higher intesity color arrays being displayed on the screen. When you go to darker toned pictures the intensity of this static noise is not as apparent.
    it is coming from more the left side facing the screen, so it must be associated with z-sus board. where do i order these parts and can i make the repairs or do i need a certified tech?
    thank you for correcting me. that's exactly what it sounds like "voltage ringing" and it has gotten louder over the course of time...i think you have nailed it!
    ouch! that really hits the wallet hard...i may just live with the noise until it gets to a level that cannot be tolerated. is there a way to prevent this from happening again, once it has been repaired?
    i suspect this is not related just to this model and could happen to any form of flat panels regardless whether they are lcd or plasma based? i'll just have to take my lumps at some point and dish out the $$$
    thanks for your comments and technical advise in matters.
  • 4,889 Answers
DId you try a different cable? If not try and let me know so that we can get on with any repair work..
Posted on Feb 17, 2008
  • Hitachi Master
  • 19,396 Answers
Does the noise increase of volume when you turn up tv volume?
    Sergeant:
  • 395 Answers
I've had this happen to a customer of mine, we found that the cable box was not grounded to the house ground to prove that it was not the TV we used an adapter to remove the ground from the TV.the noise went away. we also removed the cable the cable box then used the dvd player thru component and there was no noise. we had the customer call the cable co. to resolve his issue. so try it and see if the noise goes away.
if it doesn't replace the SSB board.
  • 3 more comments
  • Robert Johnson Feb 17, 2008
    since this is not audio problem, listen for the noise to come from the left of the unit, or the right of the unit facing the screen. if the noise is from the left replace the z-sustain board inside the set. if from the right then replace the y-sustain board inside the set.
    z-sus pwb part # TS05681
    y-sus pwb part # TS05679
    these boards are not component level repaired board only repair.
    the ssb is the input board also know as the video card. but since this is not an audio problem this board is not the fault. the sustain boards drive the display and use high voltage. static discharges are not normal but voltage ringing from the coils are normal to an extent. they get louder when contrasted bright sceens are present. but if this is too loud then you must replace the components in the scan ciruit. lastly, not be a downer but, the panel can cause the sustain boards to over drive and soon fail. but the first paln of attack is the sus boards.
    you can get them from www.vancebaldwin.com price $218.10. if you are not familar with plasma repair do not attempt the repair yourself you may cause problems inside (fragile ribbon connectors inside). any qualied tech can do the repair. but I've said it before DYI's go at your own risk it's your money (life). good luck!
    unfortunatly it's due to capacitor on the sus boards changing value past the tolerance of the writen value. again the panel can cause the over driving of the sus boards too. there is realy nothing you can do to prevent this it is the nature of the components insde.
    yes that is true it's not brand specific or style of electronics. the components within the set can be made by dozens of manufactures but only assembed in one or two factories.
    ddon't forget to rate my solution as fixya thanks.
    President:
  • 1,944 Answers
Are there any cables overlapping?
  • 2,336 Answers
It sounds like one of those cables has a defective ground. The static noise you are experiencing is cause by the cables not inside the TV. Try using different cables to isolate the problem and get new ones.
Good Luck.
  • Jaime Hernandez Feb 17, 2008
    I forgot to mention to check the source of your video as well, a loose connection or ground will cause the noise as well.
Dm605 s2 speakers have static noise
If the noise you hear comes from the tweeter or the midrange speakers, it means your amplifier is noisy; if the noise comes from the woofer, then the internal amplifier (it has its own) of the speaker is noisy. If both speakers are noisy, it is most probable that the "static noise" you hear comes from the external amplifier, which you will have to check or change.
Feb 12, 2014 | B&W DM605 S2 Speaker
Static noise
it is a faulty component humming inside. Need repair.
Oct 25, 2013 | HP Computers & Internet
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
Unable to hear AM radio Static, Whining noise,
The filter in the radio has gone bad or the antenna connection shield is not grounded properly. Electromagnetic interference is the problem. Difficult to run down. Try another radio to determine if it's simply the internal filter in the radio/audio head. If a different radio eliminates this noise, the problem is in the radio's filter. If the problem is still there, is't most likely in the antenna circuit.
Apr 11, 2009 | 2003 Hyundai Tiburon
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
Acer aspire speakers
i had the same problem on my acer aspire 6935g.
its the internal subwoofer.
i have windows 7, so to turn it off i did this:
right click the speaker icon at the bottom right.
click 'sounds', then 'playback'.
double click 'realtek speakers'.
click 'levels', then at the bottom there is a slider saying 'internal subwoofer'.
slide this to 0.
click 'ok', then close all the windows.
The internal subwoofer is off, (but can be turned on again if you want), so the crackling should have stopped.
It worked for me...
Hope this helped! ;D
Nov 18, 2007 | Audio Players & Recorders
Cable connection generating static on screen & noise
Hi, it sounds like ya most probably gonna haveta resolder the Cable Connection Socket internally.. they often fracture, OR perhaps it is the Actual Cable Connection Plug itself?.. maybe you need to remake this input connection? Indeed it sounds as if the Earth Shielding is making bad contact...
Sep 04, 2007 | Toshiba CF36G40 36" TV
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
441 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
