Question about Vivitar ViviCam 5386 Digital Camera
LCD SCREEN IMAGE IS DIM BUT ??
All the Menu items and the Vivitar images are very bright on the screen.
I am truly puzzled.
  • jimconn Feb 16, 2008
    BY IMAGE I MEAN THE PHOTO I AM TRYING TO TAKE
    Problem Solver:
  • 13 Answers
I think that you are going to need the book for this one! If the image is bright on the screen but the image comes out dark, it might be in the settings. First, try to put the camera back to factory settings and try again.
Posted on Mar 22, 2008
What does the blue light in the corner of the screen mean
Sorry could not find the exact manual. however you can find it from this one as they ought to be similar
http://www.vivitar.com/files_products/1033/ViviCam_F124_Camera_Manual.pdf
It is called the METERING MENU - three modes (Centre; multi and SPOT). you are set for that spot. you can change that. see page 23
The Metering setting will affect how your camera focuses when capturing an image. Depending on your selection, the camera will be more sensitive to focusing on particular areas in the display and adjust the image color and lighting accordingly.
Center - Averages the light metered from the entire frame, but giving greater weight to the subject in the center
Multi - Used in standard conditions the camera divides and adjusts the settings of the image into several zones for light metering such as complex light conditions, position of subject, brightness, background, direct light and scenes
Spot - Meters the area within the spot point frame at the center of the LCD to set the exposure on the subject in the center of the monitor.
1) Press the M (MENU)/SET button to open the menus for the current mode.
2) Press the LEFT or RIGHT direction control buttons to scroll and select the chosen menu.
3) Press the UP or DOWN direction control buttons to scroll through the menu options.
4) Press the M (MENU)/SET button to select the desired option.
5) A selected option icon will appear on the selected item.
6) Press the LEFT or RIGHT button to select the next menu item. 7) Press the MODE button to exit the menu and return to your previous mode. 23
8) An icon reflecting your selection will display on the LCD screen 9) Remember that this setting will be saved by your camera until you manually change the setting or restore the camera?s default factory settings.
Apr 12, 2016 | Vivitar ViviCam 3188 Digital Camera
Sony Vaio E Series VPCEH37FX screen goes dark, but fine otherwise
If you can see faint dim images on the screen, then your back light or power inverter has failed. They are not adjustable or repairable and must be replaced. If you can't see anything on the screen, the LCD has failed and must be replaced. Sometimes it's hard to see the dim images so use a flashlight to help determine if there is any image on the lcd.
Oct 27, 2013 | Sony VAIO Computers & Internet
The LCD screen is too bright, cannot get a clear image. dont know why. it does take normal pictures, but cannot see what i am taking a picture of, or read the menu properly. please help. henry
the lcd screen turns dim or indistinct,it means it is in a bad condition. the lcd screen needs to be protected properly especially for a long time use.you can buy a new lcd or find a replacement.
http://www.digitalcamera-parts.net/
www.skiliwah.cn/
e-mail:e-8090team@hotmail.com
cindy
thx
Aug 27, 2011 | Canon PowerShot A490 Digital Camera
LCD screen - "no image" reads on LCD vivitar screen
Contact Vivitar and see if they can help. There have been some problems with images on some cameras. Vivitar may fix this for you.
Apr 21, 2010 | Vivitar ViviCam 35 Digital Camera
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
Adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Acer Aspire 5630 Notebook
Screen is very dim..can barely see it..bright adjust doesnt help.
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
May 17, 2009 | IBM ThinkPad T20 2647 Notebook
Dim Screen when Power is Unpluged
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 27, 2009 | Dell XPS M1330 Notebook
Pictures won't show on screen
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Jan 21, 2009 | Nikon D70s Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
52 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
