Question about Beko 24 in. D3421F Free-standing Dishwasher
Dishwasher won't drain
It's actually a de 3430f but that doesn't seem to exist.
I have a brand new (less than one week) Beko dishwasher which isn't draining. originally we had a hose extension which was too long, there were kinks. we bought a smaller extension, and have installed it in exactly the correct way that it wants, but it won't drain. Originally it took the water in but wouldn't drain, not it seems it won't do either, presumably since it won't take in water while there already is some in the pipe.
Any help would be greatly appreciated,
thanks
  • 1 more comment
  • babydull Feb 16, 2008
    yes as far as I can see it's totally unpackaged. argh, that is so frustrating! i thought perhaps it was a problem at my end.
    I realised I hadn't removed the sink pipe plug. solved!
    thanks for the help though.
  • Anonymous Mar 23, 2014
    is it possible to run on hot water supply only,
    model is beko de 3430f,
    many thanks
  • 417 Answers
Check that you have removed all the packaging pieces from the unit, If this still doesn't work then return it to the store and get a replacement.
Thanks J
Posted on Feb 16, 2008
  • Jason Collin
    Jason Collin Feb 17, 2008
    no problem just takes a second look.
    Thanks J
My dishwasher does not receive water
You may have a defective/stuck overfill valve. If it isn't operating correctly, it won't allow water into the tub, or too much.
May 12, 2012 | Beko Dishwashers
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
May 09, 2010 | Dishwashers
Water not draining from diswasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
I have a Beko DE 2541f slimline dishwasher and it seems to have got stuck draining - have switched it off and removed power completely but it just starts draining as soon as it's switched on again. Any...
hi there.......your problem can occur when the sump of your apliance becomes flodded....this activates the anti flood switch which causes the drain pump to run....soloution is to dry out the sump or remove machine from its location...tilt it back letting excess water flow from the sump..check that all fixing screws in cabinet are secure including the air vent (mid way u the left/rt hand side of inner cabinet...
test appliance again if problem persists you will need to change the water flow meter
regards Sir Galahad
Jun 29, 2009 | Beko 24 in. D3731F Free-standing...
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
Beko DE 3762F
Dave, Could you provide more details ? - Does it drain out water at the beginning of the cycle? - Does it fill with water ?
Aug 07, 2007 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3421F Free-standing Dishwasher Logo
434 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
