Question about Garmin StreetPilot c530 GPS Receiver
Garmin c530 My screen is locked up on the page you type an address on. It won't respond to the power button.
  • bshervais Mar 18, 2008
    It turns on but the where to and view map and menu do not respond when pressed. I tried holding the lower right front and turning on, got the black dots but the fourth one did not respond at all, locked up and I had to turn off and restart.
Carefully remove face plate bezel. There is a reset button on the right side of the face. Press the button and then restart normally. It's in the owners manual if haven't lost yours like I did. The manual is on Garmins website.
Posted on Feb 17, 2008
Garmin does not read sd card
What size and type of SD card is being used?
The Garmin StreetPilot C530 will not support SD cards larger than 2GB or SDHC cards.
Sep 19, 2011 | Garmin StreetPilot C530 GPS Navigator GPS...
Garmin c530 just gets warm, won't power on, won't charge.
try resetting the unit by popping off the frame around the screen where the reset button is.
Oct 23, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jul 10, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 does not turn on
Replace the battery 3 years is the maximum life of the battery
Jun 11, 2009 | Garmin StreetPilot c530 GPS Receiver
How to reset garmin c530? thanks.
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
Regards
Richard.
May 18, 2009 | Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
Does not select the letters that you want
I saw that someone suggested that I hold the power button for several seconds
until i got more on screen instructions - follow the bouncing dot and it seemed to
clear the problem - time will tell
Apr 12, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin Streetpilot C530 is locked up and can't even be turned off.
There's a reset button under the trim ring around the face of the unit. Gently pry off the trim ring by hooking a fingernail in the little groove under the logo, then press the reset button. Page 20 of your manual says if you have to reset often, then you might need to update the unit's software. But I wouldn't recommend it if this is the first time.
Aug 06, 2008 | Garmin GPS
Garmin C530
There is a Master Reset procedure, but you would lose all of your favorites if you did it. To do a Master Reset, turn the unit off. Press and hold the on button and the bottom right of the screen at the same time. Release the on button when the unit comes on and asks if you want to do a Master Reset. Again, this will ERASE ALL OF YOUR FAVORITES.
Mar 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 street pilot
My Garmin c350 has a green screen after trying to update it for the first time and my computer will not read that it is connected.
It will not shut off after holding the power button down for 3 minutes
Dec 13, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
77 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
