Question about Acer Aspire™ T180 PC Desktop
Speakers i been trying for two hrs to get my speakers to work.i looked at your description for the back panel,its no help.it came with two speakers,there a line for in and one for out.but i can not tell where they go. i get no sound at all.please help i can no talk so the phone will not work.
  • crazy-39 Feb 20, 2008
    checked panal they are on and i have it plugged in the back in the black one cant get sound.
  • 73 Answers
Ok.. get some earphones, nice simple walkman dollar store earphones. Put a cd in the cd tray or play an mp3.. look in the back of the pc for a green jack.. try it, try them all. Then look on the bottom right hand corner of the screen, any little speaker icon? open it, set the volume? No speaker icon? control panel, sound, make sure there is a sound card listed.
Work backwards logically with known working equipment.
Posted on Feb 16, 2008
SOURCE:
Push power protector
Do a cold reset, page 90 of your manual. Push power button, stop button and disk eject at the same time. Wait 5 minutes and turn back on. Look on page 90 of the manual. This worked for me after trying over a year. I beat I didn't have 25 hrs on mine. Good Luck
Nov 30, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Description to pins of a car radio
Starting at the upper right (UR1) when looking at the rear of the unit: UR1 is 12v power; LR1 is ground; UR2 = Ignition power; LR2 = Panel light lead; UR3 = Unused; LR3 = Power Antenna lead; UR4 & LR4 = Right front speaker; UR5 & LR5 = Right rear speaker; UR6 & LR6 = Left rear speaker; UR7 & LR7 = Left front speaker; UR8 & LR8 = Unused.
Jul 29, 2012 | Virtual Reality VRCD500-SDU CD Player
My JBL PRX 635 Speakers at all event shuts off during high volume ( No Red Light ) Very Embarrassing during the dance is packed. Volume is always set at one single yellow peak from the mixer and just...
Sounds like you're over driving them. First check to make sure they're on "line level" not mic. Shutting off is amp(s) in speakers going into "thermal shutdown" IE: overheating. According to your description level settings look good - check to make sure speakers are on LINE LEVEL
Apr 12, 2011 | JBL PRX635 Speaker PA Active
Hi i have the Bose companion 5 speakers today there was a power cut in my flat. after that my speakers are not working anymore. the thing is that the led on volume control is on (green) and my pc...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 30, 2011 | Bose Companion 5 Multimedia Speaker System...
Hello,i have a problem regarding to my pc because there was no sound eventhough i downloaded the sound driver,it is not working. I've just reformat my pc. i really don't know why the sounds not working....
also
hope this helps
Mar 30, 2011 | EliteGroup ECS 661FX-M Main Board Socket...
I can't heard no music why?
Several possibilities come to mind: speakers have failed (self-powered speakers have bad power brick, cable damaged, etc), speakers plugged into the wrong port (audio in instead of audio out), audio card or driver has failed.
If you recently had to restore your OS (or do a roll-back to a "known" good configuration), check your audio device (make and model) and make sure you have the latest driver installed. (Look at the website for your computer if it is a prebuilt system or look up your motherboard if it is an on-board audio device.) The device manager might have a yellow exclamation mark on the audio device if this is the issue (access from the Windows Control Panel)
Check for bad speakers by trying another set of speakers or plugging them into another computer. (Swap cables if that is possible.)
I hope this helps.
Apr 23, 2010 | Dell Inspiron 530 Desktop Computer
Hello, I connected my Bose Companion 3 system that I bought in the US, to 230V when I brought it back to India. There was a hum in the acoustimass unit as soon as i turned it ON and then it simply died!...
It is 94/100 % sure it is smoked. You can look inside for a fuse, but based upon your description, there proabbly is not one.
Im sorry your smoked your new system.
Thanks for your question here at FixYa.com
Jan 09, 2010 | Bose Companion 3 Computer Speakers
I've aproblem with sound
check the sound  settings, double click the speaker icon there in the bottom right panel window.. the volume control window will appear, check the balance controls etc. hope this will help.. [:0)
Oct 01, 2007 | ASUS P5S800-VM Motherboard
Acer Aspire™ T180 PC Desktop Logo
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
