Question about Mitsubishi VS-55705 55" Rear Projection Television
Sound but no picture on a Mitsubishi VS-45VA2.
I have a Mitsubishi VS-45VA2. The sound is great, but I can't get a picture. I took the back off to check fuses but none appear to be bad. It was very dusty and I cleaned it out as best as I could. There appear to be no burn marks from bad components. What is my next step?
thanks.
  • 2 more comments
  • alvada Feb 18, 2008
    My son was playing his XBox and the game appeared to have locked-up. When he restarted the XBox the screen had 10" back bar at the top of the screen. After turning the TV off and unplgging the power in an attempt to reset the TV, when the TV was turned-on the sound came on but no picture. I have turned off the TV and waited an hour but when I turned it on there was still sound but no picture. Since the XBox is High Def we had tried to connect it to the DTV jacks on the TV to get the 1080i picture without success. This time we had it plugged into the TV's DTV jacks but had the XBox set on standard TV (not HDTV). When set on HDTV we got distorted horizontal lines. HELP!!
    The model of our Mitsubishi projection TV is WS-65807
  • Jaiden73 Feb 19, 2008
    "Two other questions do you have video through the pip with the
    alternate input? and do you have on screen display when you push menu
    on the remote?"
    I haven't checked that yet. I wanted to try and get something through the picture tubes before I spend the money on a remote. I know it's a catch 22 because I need the remote to check it out, but if the TV is beyond repair I'll have a useless remote...
    Surprisingly, I somewhat understand what you are telling me to do with checking all the pins. If only I had a multimeter.
    I'll check back when I have some meore news. Thanks a bunch!
    D.
  • jrayschell Jan 26, 2009
    Same problem. Sound is great - no picture. I can change channels w/remote fine but still no picture. We put in a DVD & it worked fine w/picture for about 5 minutes but then started going out and within a few minutes - nothing. So I'm guessing it's the picute tube, now finding an honest technician....
  • Mitsubishi Master
  • 8,617 Answers
This is the VZ1 Chassis.. CHECK FOR 1200 VDC AT PIN 1 OF CONNECTOR "DK". IF LOW OR MISSING CHECK R5D9 100 OHM 1/2 OFF PIN 1 OF THE FLYBACK ON THE MAIN PCB. 2. CHECK IC401 PIN 8 FOR 28 VDC IF MISSING CHECK R510 1.2 OHM 1/2 W OFF PIN 5 OF THE FLYBACK. IF OPEN IC401 PART # 272P239 If those voltages check out let me know and we will go to the next level. Two other questions do you have video through the pip with the alternate input? and do you have on screen display when you push menu on the remote?
Posted on Feb 16, 2008
I have sound but no picture on my mitsubishi VS-45VA2, what can I do to solve this problem?
Well, today may be your lucky day. This is a 200.00 repair at least, but I'll attempt to help you for free. Most commonly on this set the pip module fails. This is a small standup board mounted on the signal pcb. There are 2 plugs that connect it to the signal board. These plugs are VS and VA. First, Disconnect the power to the tv and remove either the front or rear cover. Use good lighting. Disconnect small standup board from signal pcb using a small screwdriver to undo the two clips at VA and VS connectors. Pins of the VA connector are marked on the board so you can tell which one is pin 1 through 11. Simply jump a small wire from pin 5 to pin 11 and a small wire from pin 7 to pin 9. Make sure the wires do not touch and this will bypass the pip module for testing. With pip module removed and 2 jumpers installed plug set in and turn on. The set should now show a picture but the pip will no longer work. Hope this helps. Good luck, Russmann.
Jun 10, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50501 no picture sound works great
Odds are real good that the solder connections on the deflection yokes are bad. Go through the front access panel and with a small mirror look and the back side of the connector on each yoke. The top two pins of each will probably show 'ringed' solder connections.
May 07, 2009 | Mitsubishi VS-50501 50" Rear Projection...
I have a vs-4543 picture only works part time sound always works
most likely bad solder connection or cold solder connection which is making contact after the set is moved or vibrated doe's this happen right away
or after the set is warmed up
May 07, 2009 | Mitsubishi VS-4543 45" TV
Shrinking picture..
Vertical circuit problem. VERY common on Mitsubishi sets for past 30 years. The capacitors are getting weak. Have it checked out, aslong as the picture was good and clear before the problem. That just means the tubes are still O.K. Mitsubishi's ALL have bad capacitors all over them. Been like that for ever. If you wait too long, the caps will leak onto the circuit board and "eat" the circuit traces. It should be checked ALL over for bad caps and then have the convergance chips replaced with original sanyo made replacements.Very inportant! Take the time to find a good repairshop in your area. Talk to other people to see who they use. You're talking about $400.00 to do everything, but it will last for years after that. If you like the set, it's worth it. Just be honest to your-self when evaluating the quaility of picture you had and get a good repair shop. That's the best advise I can give you. Good-Luck.
Dec 06, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
No picture or sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi vs-45va2
Can you be more specific? What kind of distortion are you talking about?
Jan 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Model # vs-45va2
Does it operate at all, or does it start to power up then shut down?
Oct 19, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
264 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
