Question about Caliber P-3600 GPS Receiver
Problem with P-3600...no map!
We have tried multiple troubleshooting ideas, but nothing seems to work. We bought 2 of these systems. Both had no voice guidance when we purchased them. One we have fixed using the troubleshooting info from website. The other did not work, plus now the map will not even come on when you push Navigation. The other options on the menu will work. Please let us know if you have any suggestions!
  • roland_leblo Feb 10, 2009
    looking for canadian map for my caliber p-3600
How can I get canadian install in gps p-3600caliber
Posted on Feb 10, 2009
What is code #code p1296
Definition of Diagnostic Trouble Code P1296 Audi: Cooling system malfunction Chrysler: No 5 volts to MAP sensor Dodge: No 5 volts to MAP sensor Ford: Injector Multiple Faults - Bank 2 Jeep: No 5 volts to MAP sensor Lincoln: Injector Multiple Faults - Bank 2 Mazda: Injector Multiple Faults - Bank 2 Mercury: Injector Multiple Faults - Bank 2 Mitsubishi: MAP Sensor 5-Volt Supply Fault Volkswagen: Cooling system malfunction
Jun 08, 2010 | Volkswagen Jetta Cars & Trucks
My old garmin 3600 Ique has some problems. I
the software for running the maps is not compatible is the cause.
Nov 04, 2009 | Garmin iQue 3600 GPS Receiver
I just upgraded to 2009 US maps and the GPS voice has worked once
I had the same problem. I had to have the dealer reload the GPS software once I got back to the states. It took two tries, but once actual GPS software was updated with the U.S. software version it worked find.
Jul 26, 2009 | 2006 Volvo XC90
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
Unlocking IQue 3600 maps
Even with the maps unlocked it they can appear to be locked.
There are little known flags to diable/enable the base/detailed maps.
Check that the boxes are checked under the <Map><Options><Misc>
You can select either base or detailed maps there.
Disable both and it looks like the unit doesn't have any maps.
Aug 21, 2008 | Garmin iQue 3600 GPS Receiver
Tomtom 920T voice recognition route planning
You have to have the cspeech files in your map of England for voice recognition. Cspeech is only in the larger maps.
Mar 22, 2008 | Tomtom GO 910
I can't seem to enable to voice prompts
Taken from the Garmin website:
"This error is most likely caused because the voice files need to be reloaded onto the iQue. Insert the iQue setup disk and select 'Install Software'. Then select 'Change voice'. Then select the voice to be installed on the device. When the voice files are finished installing, perform a Hotsync. The voice guidance files will then be restored to the unit and the voice prompts should work correctly."
Feb 26, 2008 | Garmin iQue 3600 GPS Receiver
Navigation voice is gone
Happens when you run out of batteries. You need to re-HotSync and the voices should come back.
Dec 15, 2007 | Garmin iQue 3600 GPS Receiver
Garmin nuvi 350 troubleshooting
1)Does it make beeping sounds when you touch the screen buttons?
2)Can you hear the voice when you listen through an external headset?
If your answer is no to #1 and yes to #2 then you may have a dead speaker.
In the setup screen there is a way to select different voices/languages.  Try a different voice.
When those models first came out there was a problem with the software not recognizing the voice files.  There was a free update done to correct the problem.  If your current software version is less than 5.00 you should update.
Here's the update page:  http://www8.garmin.com/support/collection.jsp?product=010-00455-00
Oct 26, 2007 | Garmin nuvi 350 GPS Receiver
Caliber P-3600 GPS Receiver Logo
107 people viewed this question
Top Caliber GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Caliber GPS Expert? Answer questions, earn points and help others
