Question about ViewSonic VE175b 17" LCD Monitor
My monitor stopped working
How can I fix it ? Is it power supply or or something else?
  • 2 more comments
  • LINAKHL Jul 06, 2008
    NOPOWER AT ALL HOW TO OPEN THE MONITOR COVER TO ACCESS THE POWER SUPPLY.
  • Anonymous Oct 09, 2008
    There is power to the monitor as the pwer light is ON on the monitor but there is no image on screen. If I press power button OFF on monitor and then press power button back ON I see the monitor and image on screen for just a sec and then monitor screen goes black.
  • pattykakesda Dec 27, 2008
    my monitor does the same thing. I power it on and sometimes you get a image and sometimes you do not. After turning it on and off a couple of times you get an image, but if you have to re-boot for any reason, again no image.
  • Anonymous May 14, 2009
    Sometimes after the monitor has been on the picture goes completely blank and I have to turn it off then on again to get the picture back. What is the problem?
    Champion:
  • 220 Answers
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Posted on Feb 17, 2008
No power totaly dead lcd monitor viewsonic VA702b model # VS10781,,,
Posted on Aug 09, 2008
Do you have Schematic for my monitor
Hi
Dont think they are available any more. It's becoming a throw away world.
I used to fix them.... without a schematic. Your local TV technician can often assist with repairing an older style monitor. e.g. CRT tube type.
Modern monitors are LCD & digital electronics. Although they still blow fuses & have switch mode power supplies with leaky electrolytic capacitors that stop the power supply from working.
If your knowledgable in this field then I would start with a visual of the power supply. Be careful of the shock hazards.
Good Luck
Trevor
Sep 06, 2014 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
Power supplies tend to be either working or not working. I would start with the computers memory, reseating the memory cards (there are plenty of tutorials on the web for how to do this). If the power supply fan was running, chances are you did not need to buy a new one. Does it do the same thing with the new power supply?
Apr 15, 2011 | HP Pavilion Elite M9060N PC Desktop
The monitor goes dark within a few seconds of turning it on. Is this something that can be fixed or do I need to replace?
Try replacing the power cable. (assuming that the monitor has not lights when it turns off) After replacing the power cable if that doesnt work try a different outlet.
If there are lights try seeing if you can replace the data cable from the monitor to the computer. If that doesnt work then you will want to look into getting a replacement.
Mar 01, 2011 | MegaVision Hyvision Megavision 191 19"...
My dell desktop 530s stopped working and now the fan only turns on and the power button is illuminated in yellow, not blue. Please how I can fix this problem. Thanks
This is the explanation according to the service manual.
This is a system fault error condition, including the power supply. Only the +5VSB rail on the power supply is working correctly.
  • Ensure all power cables are securely connected to the system board.
  • Ensure the main power cable and front panel cable are securely connected to the system board.
note.gif NOTE:
If the system was abnormally turned off, you need to disconnect and plug in the AC power cord. Then turn on the system. Otherwise, you may see an incorrect power light state.
You either have a bad power supply or something is shorting out your power supply. Disconnect all devices from your computer except the monitor, keyboard and mouse. Also check your USB ports to see if any are damaged.
Jan 09, 2011 | Dell Inspiron 531s Desktop Computer
The hp mx 705 monitor was working,then it just went blank and black. the power button light, just blinks green.
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
Nov 07, 2009 | HP mx705 17" CRT Monitor
LCD monitor stopped working on my CPU but works on my Brother's
Definitely some electrolytic capacitors are blown inside the monitor in power supply module. Open it and observe any of them rounded on top, replace with proper ones.
You see, controller operations with VGA and DVI inputs takes different current from the supply, that's why it may take different time until PWM chip in the power supply will decide it is time to shut down before getting smoked.
Replace capacitors.
Sep 06, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Ds-1107a inverter/power supply no power or comes on &LCDflickers
Classic sign of bad inverter. Since it is inside the LCD not something you can fix yourself unless you work with electronics. Needs to go to the repair shop.
Jan 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Stopped working suddenly after 18 months daily use
It appears either the inverter supply board or the main video board have failed. First replace the inverter board, if not fixed, replace the video board. Mike
Aug 09, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
ViewSonic VE175b 17" LCD Monitor Logo
408 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
